C**ls@ 5k
Username: Csb3
Post Number: 33
help need a loader & latest fix
thx
Username: Kirankumar
NO Bashing
Post Number: 3059
go to www.ftabins.net or any other reputable site,with free registration
Username: Csb3
Post Number: 34
i have evrything i need now how do i use the loader it is different from the pans@
Username: The_coders
Post Number: 1483
Loading New File To CooIsat 5000
With the receiver connected to the TV>
Go to menu/system settings/Data base reset/enter 0000/Factory set/press OK/ select Yes/
* Power Off receiver using switch on back of unit & disconnect from TV
* Connect receiver to PC using supplied cable & and plug in AC power cord
* Turn receiver power switch back on.
* Open up CooIsat Pro Loader File
* Hit Auto Detect--Exit
Using browse option, locate and select **CooIsat 5000-100-20060308 stb.
* You will now see the file in the display box in the proloader, click "Connect"
**This will load the original factory program to the receiver. You will see new files loading to 100%, and then old files erasing and writing up to 100%.
* When complete, power off the receiver.
* Disconnect the receiver from PC
* Reconnect the receiver to your TV and turn power switch on.
* Using the remote, select System Setting in the main menu, in the submenu select Database Reset, and then Factory Set, Press OK
* When factory set is complete (language option screen appears), power off receiver and disconnect from TV.
* Reconnect receiver to PC and switch power back on
* Using browse option, locate and select from your folder the New NorW STB file.
* You will now see the file in the display box, click connect.
* eg. CooIsat 5000-162-STB Once again, you will see the new files loading to 100% and old files erasing to 100%.
* When complete, power off the CooIsat and disconnect from PC
* Reconnect to TV and switch power back on.
* Using the remote, select Menu --> System Setting --> Database Reset, enter passworld and select Factory Set, Press OK
After you click on save you will be back in Main Screen.
Select language you want
