Lanzar OPTI1232D vs Power Acoustik MOFO
Username: Subbin
Post Number: 8
Im thinking of getting one of these 2. Which one should i get? If there are better subs than these at a better price please share. my budget 150$/ ea for a sub its going into a new 2009 c300 benz, i would like a mix of sq and spl
Lanzar OPTI1232D$149.00 www.onlinecarstereo.com
* Sensitivity: 88 dB
* RMS Power Range : 1100 Watts
* Peak Power Handling: 2200 Watts
* Impedance: Dual 2 Ohm
* Low Frequency response: 26 Hz
* High Frequency Response: 800 Hz
* Diameter: 12 Inch
* Custom Tooled Die-Cast Aluminum Basket
* Aluminum Alloy Cone Structure
* Massive Butyl Rubber Surround
* 3" High Temperature Dual Voice Coil
* 65 Oz x 3 High Density Barium Ferrite Magnet
* Power Handling: 1100 Watts RMS/2200 Watts Peak
* Frequency Response: 26- 800 Hz
* Impedance: 2 Ohms DVC
* Efficiency: 88dB
* Includes Installation Hardware and Template
Power Acoustik MOFO $129.95 www.caraudiodeals.com
* Brand New Power Acoustik MOFO12 2400W 12" Subwoofer
* 2400W Max Power
* 1200W RMS Power
* 270 Oz. Magnet
* 3" BASV/Kapton Hybrid 18 AWG Voice Coil
* Non-pressed paper cone with aluminum rib insert (patent pending)
* Dual 2 Ohm voice coil
* Die cast aluminum
* Metal-flake Royal Blue Finish With Diamond Cut
* Chrome Finish Front & Back Plate
* Large foam rubber surround
* 1-Piece Rubber Gasket
* Dual Conex Spider
* Woven Tinsel Lead Through Spider
* Chrome Screw Terminals
* Mounting Depth: 6-1/2"
* Deluxe Wood Case Package
Username: Surferdude9371
Get loud or go home....
Post Number: 1466
im SURE we can get you a better sub in your budget. what is your budget? what vehicle is this going in? do you want sq spl or sql a mix of both?
Username: Subbin
Post Number: 9
my budget 150$/ ea for a sub its going into a new 2009 c300 benz i have no idea wat is sq or sql
Post Number: 1467
sq= sound quality
spl= pure loud bass
so your planing on getting 2 subs? how much of your trunk are you willing to give up?
Username: Subbin
Post Number: 10
im only getting one sub and i would lie ka mix of sq and spl, trunk space does not matter.
Username: Subbin
Post Number: 11
im only getting one sub and i would like a mix of sq and spl, trunk space does not matter.
Username: Ducka
Houghton and/or Macomb, MI United States
Post Number: 769
Alpine Type-R 12 or Audioque 2.5 12" or 15"
Just to name a couple... There are better subs for the price you mentioned.
Username: Subbin
Post Number: 12
I was thinking of getting type R but for the price and the watts/ rms these looked better
Username: Ducka
Post Number: 771
yeah, but unfortunately they are bad quality. And they type-r can handle over 500wrms.
Username: Subbin
Post Number: 13
ya most likely
Username: Ducka
Post Number: 774
I think you should get the 15" Audioque SDC2.5
http://www.audioque.com/aq/SDC2_5_Series.htm
Username: Subbin
Post Number: 14
How much do they cost and do they bump?
Username: Subbin
Post Number: 15
How about the Fi BL's ?
Username: Hittin1
Lake Charles, La. United States
Post Number: 1686
"How about the Fi BL's ?"
At least your on the right track.
What amp are you using?
"my budget 150$/ ea for a sub its going into a new 2009 c300 benz i have no idea wat is sq or sql"
This is going into a brand new Benz and your budget is $150?
used fi q
perfect kappa
used Alpine type x
used id-Q
these subs get decently loud but have great sound quality
I would not go to heavy with the SPL with that car. You dont want the wear and tear on that car.
Username: Mmaudioconcepts
Post Number: 585
get the optidrive, most people on this site have not hear it or even seen them. I sell them and they pound. The sq is not bad either. Its the best thing lanzar has made.
Username: Subbin
Post Number: 16
"You dont want the wear and tear on that car"
Very good point
Username: 420alldaylong
Post Number: 3890
RE SE 12" off ebay BNIB with 2yr warranty.
Username: Redliner
Wilmington, Ma
Post Number: 4688
i recommend u just get a 13 w6v2 not sure on the price but it will be perfect for ur car. since you dont want huge groundpounding going. rattling that car wouldnt b good lol its to nice
Username: Teamdeboy1971
OPTIDRIVE LN., TN Major Bass P...
Post Number: 542
I would suggest Lanzar Optidrive 1232 I have owned them and they are crazy loud! If the bass is too much you can adjust it alittle, I would rather have too much than not enough! You can always bring the BUMP down a little and the price range is good! I have had 2 of them for almost 3 years and there still bumping!!!
Username: Jason420
PIMP CITY, GA USA
Post Number: 8
Power Acoustic i mean the double magnet one is good but i seen a 300wt Memphis amp blow it up. alpine subs pretty good they are 4 sq period sure they hit but very short life re subs great cost $200+ JL audio great cost too much what type of amp u got what ohm load can it do
Username: Tatonka
-[Team Audible Insanity]-
Post Number: 2471
New people posting advice?
Jason, you are on the right track man, but please start reading a little more.
Username: Drant19
DUB-C, TX
Post Number: 1329
jason please use punctuation where it is needed.
"alpine subs pretty good they are 4 sq period sure they hit but very short life"
uhhh iver never heard anyone say that alpine subs have a short life. if you abuse it, then yes it wont last long, but thats just like anything else you use.
Username: Hittin1
Post Number: 1730
he is WAYYYYY off base on that comment..
