BRUTUS TROUBLE, PLEASE HELP
Username: Slammin21
alright ive got a Brutus 1200 watt amp with the 4 guage kit hooked up to two 12" kicker CVR'S. The problem is that when i turn the radio up the amp shuts off therefore not giving me the full potential.Do i need a bass cap or a audio battery or something? any suggestions?
Username: Snowball123
West Allis, WI
Post Number: 1470
cap is a no-no. What is your stock alt right now?
Username: Nd4spd18
Philadelphia, PA
Post Number: 8689
Is your gain set right, and what ohm load are the subs wired to.
Username: Tejcurrent
Post Number: 1584
I'd say check the ohm load if it's cutting off before you really crank on it. Those amps don't like <1ohm for any duration from my experience.
Username: Hittin1
Lake Charles, La. United States
Post Number: 1721
what VC configuration are the CVR's?
