Silver Member Username: MmaudioconceptsPost Number: 584 Registered: Jan-07 | ok so i upgraded from an 1800wrms to a 4000wrms amp. Im thinking two loaded BL 12s. In the price and performance range what compares to the BLs in overall output and sound quality. |
Gold Member Username: Hittin1Lake Charles, La. United States Post Number: 1696 Registered: May-07 | Revo's ssi or ssx dc lvl 3 dd 3512 rd alpha re sx idmax si mag rl-s plenty of others |
Gold Member Username: MgbcsMaple Grove, Minnesota Post Number: 2691 Registered: Dec-06 | A few of those are a little out of the BL price range. But still a great list |
Gold Member Username: Hittin1Lake Charles, La. United States Post Number: 1697 Registered: May-07 | some used ;) |
Gold Member Username: BonhamdPost Number: 1494 Registered: Nov-07 | re xxx - i think kevin got his on ca.com for 300 each mmats juggs AQ HDC3 fi BTL dd 9500 you can get some good deals on caraudioclassifieds.com and caraudio.com |
Silver Member Username: MmaudioconceptsPost Number: 586 Registered: Jan-07 | how much power do the btls need. off of 2000wrms what has the potential to be better between the BTLs and the BLs |
Gold Member Username: Surferdude9371Get loud or go home.... Post Number: 1468 Registered: Mar-07 | off 2kw 2 bls or 1 fully loaded btl off the 4kw |
Silver Member Username: Yukhui4 15 AA Havocs, Memphis 4kw!! Post Number: 975 Registered: Jan-06 | What vehicle do you plan on putting the system in? |
Gold Member Username: TejcurrentPost Number: 1614 Registered: Apr-07 | The BTLs should be louder off the given 2000w rms a piece. There was a big long thread on another forum involving sensitivity and other things. |
Silver Member Username: MmaudioconceptsPost Number: 588 Registered: Jan-07 | this particular system is going in a 2000 Grand Prix or an F150 XLT extended cab w/out bck seats. |
Gold Member Username: BonhamdPost Number: 1497 Registered: Nov-07 | if i had that choice i would put it in the truck - you can get it louder easier maybe bump up to 15s or 18s |
Silver Member Username: MmaudioconceptsPost Number: 590 Registered: Jan-07 | i have to have a system for both, id like to do the grand prix first. i would do 15s or 18s in the truck. |
Bronze Member Username: Lil_justin850Justin smith, crestview, Fl Okalossa Post Number: 31 Registered: Sep-08 | id say that you listen to troy and then go watch his vids on youtube btls ftw |
Gold Member Username: Surferdude9371Get loud or go home.... Post Number: 1469 Registered: Mar-07 | id do 1 fully loaded btl18 or 2 reg btls |
Silver Member Username: MmaudioconceptsPost Number: 591 Registered: Jan-07 | im thinking about two BTL 12s now. or I might do a single 15 loaded. |
Gold Member Username: BonhamdPost Number: 1503 Registered: Nov-07 | i vote for the 12s if you have the monies |
Silver Member Username: MmaudioconceptsPost Number: 592 Registered: Jan-07 | should i get any option or just stock |
Gold Member Username: BonhamdPost Number: 1506 Registered: Nov-07 | it really depends on what you want to do do you plan on running more to them later on? the options wont hurt you besides the money factor |
Gold Member Username: BonhamdPost Number: 1508 Registered: Nov-07 | http://www.caraudioclassifieds.org/forum/showthread.php?t=2099 those could be good pending on what vc config you need |
