Username: Yasira28 Post Number: 1 Registered: Nov-08
Sunday, November 16, 2008 - 06:47 GMT ok so i been using this pansat 2500 clone conv to puff, but last time i try loading the file it giving me "write fail ER1' error anyone knows wats the problem, i even try changing the connecting code still nothing. Can anyone tell me wat is the problem thanx
Username: Mrgreg Ont.
Post Number: 109 Registered: Dec-07
Sunday, November 16, 2008 - 07:05 GMT Are you using cable from com port on back or usb adapator to your cable
Username: Yasira28 Post Number: 2 Registered: Nov-08
Sunday, November 16, 2008 - 14:52 GMT using com port.
Post Number: 111 Registered: Dec-07
Sunday, November 16, 2008 - 17:13 GMT Try changing your com port # each time to see if it will load from a different one.
Username: Yasira28 Post Number: 3 Registered: Nov-08
Sunday, November 16, 2008 - 22:56 GMT i did that already notihing same error
Username: Plymouth Canada
Post Number: 5713 Registered: Jan-08
Sunday, November 16, 2008 - 23:21 GMT Vasir do a hard reboot on your computer with your receiver "ON" and cable hook and retry.
Username: Yasira28 Post Number: 4 Registered: Nov-08
Sunday, November 16, 2008 - 23:56 GMT still giving me the same error. do u guys think its my reciver that has something wrong?
Post Number: 5719 Registered: Jan-08
Monday, November 17, 2008 - 00:24 GMT No Vasir, i think that it is the loader, uninstall the loader and do a hard reboot on pc and reinstall it. Before try to select port 4 then try port1. Do you use a USB - RS-232 cable?
