Conversion BIN PUFF_297
Username: Nydas
Post Number: 13037
PUFF_297 for FLU/2500 Conversion to 2700
Full kits for Latest conversion BINs and other files - also for Revert to 2500
Alternative PUFF link
Download and unzip into separate directory.
PLEASE DO NOT ATTEMPT WITHOUT READING INSTRUCTIONS.
Username: Fahadriz8
Post Number: 147
is there any freezing with this bin?
Username: Kingofdakingz
Post Number: 372
no its working good for me since 3 hours now so i think its good
Username: Mrgreg
Ont. Canada
Post Number: 80
Works good.
Username: Snw7619
Bahamas
Post Number: 233
nalin is this for B-75 pansat2700 converted. for freezing?
Username: Nydas
Post Number: 13041
There is no b75 version of conversion 297. I think, though b75 conversion BINs work well, there is not enough support, so I suggest everybody should go the PUFF route.
Username: Mrgreg
Ont. Canada
Post Number: 86
b-75 297 bin is out at Crazyfta
Username: Mainsource
I just converted to PUFF and loaded the PUFF_297 bin but it's not working. Is this bin still working or is it down? Thanks.
Username: Nydas
Post Number: 13058
PUFF_297 is working fine.
Try loading it again.
did you rescan??
Thanks for the response Nalin. I've tried reloading the bin. Tried rescanning. Tried setting the default key. Still getting the scrambled or bad channel message.
Since it's my first time converting to PUFF and using a PUFF bin, I thought I might of done something wrong but I don't think I have.
Username: Nydas
Post Number: 13068
Converting PUFF requires that you install the 253 PUFF Boot/BIN 640K
Then you install the PUFF BIN.
Full instructions are there in the PUFF kit.
If there is a problem start with installing b60 BOOT followed by the old 294T and then do the full conversion.
Going the full root you MUST do use setup and rescan the sats.
I installed everything as instructed. Still nothing. Is Bev working for this bin?
Username: Nydas
Post Number: 13088
BEV is NOT working for ANY FTA receiver except partly on Nfusion.
Ah no wonder it's not working for me. Dishnet is working but I've never used it before. What satellite is for Dishnet and which way do I point the dish?
Username: Nydas
Post Number: 13093
BEV is 82/91 degrees.
DN is 110/119 degrees
Note the 9 degrees difference.
Swing the dish 28 degrees and you should get it. You will need to adjust elevation direction as well
Thanks Nalin. I'll give it a try on a nicer evening. It's raining out there.
Username: Vinnyc
Mb Canada
Post Number: 21
my viewsat when down tonight, so I am usinf my old receiver pansat 2700 clone and is working just fine try using bin 297. it works with out frezing.
