Need some help
Username: Honcr249
ive got a diamond audio d6 1500.1, what would be better two or three ten's? also what brand treo or memphis?
Username: Nyyfan13
Yanks Fan USA
Post Number: 10687
What would be better is one you gotta ask yourself what you want. The three tens will give you awkward ohm load not that that can't be dealt with easily. Basically what it comes down to is what would work best for your amp and what you want. As for Treo or Memphis. Both brands have solid subs, but which subs are you specifically looking at? What are you looking for with this system in terms of SQ, SPL, or SQL and what is you budget for subs?
Username: Honcr249
id like to do three but im not sure if i have the space but if i can id do the treo tsx or memphis m3's. but im goin for sql!
Username: Insearchofbass
Post Number: 10878
Welcome to the forum. What are your usable dimensions? And are you going sealed or ported?
Username: Honcr249
thanks sean, i havent measured anything to the exact but ive got about 3.5 cubes. its in a 02 sport trac, cut the seat in half
Post Number: 10880
http://www.diamondaudio.com/PDF/current/D6/D6%20Subwoofer%20Manual-112707.pdf
You could go ported with a little polyfill in sheet form.
http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=3&I=22
go with two 4 inch aero ports 10.5 deep each.
Username: Rovin
1 15 = 149.5 DBsTrinidad & T...
Post Number: 14391
thats what 1500wrms
2 10s for sure ...
