Sundown Audio SAE-1200D
Username: 420alldaylong
Post Number: 3838
When did this come out?
http://www.sundownaudio.com/1200d.html
Username: Big_edge_head
Milwaukee, Wisconsin
Post Number: 2965
Not that long ago. It's supposed to be the SAZ-1500's replacement.
Username: Mgbcs
Maple Grove, Minnesota
Post Number: 2673
It's really supposed to be its replacement? It seems to me there would be a market for both of those?
Post Number: 3839
I thought they come out with a newer SAZ-1500D not to long ago.
Post Number: 2966
I remember reading on SSA that the 1200D was going to replace the 1500, but that was quite a while ago. I emailed Jacob and I'll post his response when I receive it.
Username: Southernrebel
Post Number: 7038
IIRC, the SAE's are basicly daily amps build to 'normal' spec...good power for the price.
And the SAZ's are overbuild (aka, <1ohm stable)
could be totally wrong though.
Post Number: 2967
http://www.soundsolutionsaudio.com/forum/index.php?showtopic=20944
JD - The newer 1500D came out months ago. It has a thicker heatsink to dispense more heat. Doubt it's much of a difference though as they run cool as it is.
Post Number: 2969
Here are some pics of the new heat sink:
http://www.soundsolutionsaudio.com/forum/index.php?showtopic=14044
Username: Nyyfan13
Yanks Fan USA
Post Number: 10624
http://www.soundsolutionsaudio.com/forum/index.php?showtopic=22765&st=0
http://www.soundsolutionsaudio.com/forum/index.php?showtopic=22753&st=0&start=0
Username: Denim
SoundSolutionsAudio.com, MD USA
Post Number: 813
The SAE-1200D is not the replacement to the SAZ-1500D. They are two different lines that come from two different build houses. The SAE-1200D will do close to if not more then 1500 watts, Jacob did a number of tests showing the wattage.
To expand on what Canaan said, the SAE-1200D is not meant to be stable or handle below 1ohm like the SAZ-1500D can, or meant to handle 17volts like the SAZ-1500D can.
From recent discussions with Jacob and what he has mentioned on SSA, the SAZ-1500D will hang around longer then expected as it is still very popular and a competitor favorite. The SAZ-2000D is in testing and will make an appearance sometime next year if I remember correctly.
There are plans for larger and smaller SAE models too.
Post Number: 2970
Here's an email I got from Jacob:
"The SAZ-1500D is going to remain for sale for some time still - it is remaining very popular.
We will continue offering the SAZ-1500D as long as it remains a strong seller. I expect that the SAE-1200D will gain quite a bit of popularity and eventually push down SAZ-1500D sales, though."
Username: Dakotaboi9206
Sumter, Sc United states
Post Number: 8
i dont kno who all can say this but i kno first hand the 2000d is quite well built and is a tank but i guess everyone will have to wait till release
