Bronze Member Username: Chift21Post Number: 17 Registered: Nov-07 | I need some info on beverly. I am currently on charley and I need to change. I have a couple of questions. I have a converted Fortec Ultra with PUFF bins. -1- Are the bins the same for charlie and beverly? -2- What are the sats that I need to get. I also need international. -3- I currently have the dish pro dual LNB's. What other differences are there? Can I have both Chalie and Beth hooked up. Thanks. |
Gold Member Username: JustforhahasPost Number: 1019 Registered: Jul-08 | Bev is basically DEAD and no channels, due to card swap and change to Nagra 3 encryption...KEEP CHARLIE! |
Bronze Member Username: Chift21Post Number: 18 Registered: Nov-07 | Thanks for the heads up. I was interested in some of the international channels. Do you what are still available? |
Gold Member Username: JustforhahasPost Number: 1025 Registered: Jul-08 | use Dishnet 61.5 and 118 sats for internationals... check it out...shows every channel on each DN sats... www.dishuser.com |
Platinum Member Username: NydasPost Number: 12884 Registered: Jun-06 | For a new connection, I would suggest 118.7 because many of the channels are moving out of 61.5. You will need a 33' dish and a special LNB. |
Bronze Member Username: Chift21Post Number: 19 Registered: Nov-07 | Can we get both charlie and beverly with the fotec ultra converted receiver? |
Gold Member Username: JustforhahasPost Number: 1042 Registered: Jul-08 | Bev is DEAD...Nagra 3...DN probably dead in 6 months or so with nagra 3 too.. |
Platinum Member Username: NydasPost Number: 12886 Registered: Jun-06 | qwedfqwef: If you have the latest BIN, whatever is FTA and can be decoded by the BIN will be available to you whether DN or BEV or GC |
Bronze Member Username: Chift21Post Number: 20 Registered: Nov-07 | Thanks for all the info guys. So how long before nagra 3 gets cracked? |
Gold Member Username: JustforhahasPost Number: 1085 Registered: Jul-08 | we would be millionares if we knew..and if we knew, we wouldn't tell..DN and BEV are listening.. |
Platinum Member Username: NydasPost Number: 12928 Registered: Jun-06 | Q. "So how long before nagra 3 gets cracked?" Nagra 3 has been around in Europe, I think, since the beginning of the year and not cracked yet. You can come to your own conclusions from that fact. |
Bronze Member Username: MzakcatPost Number: 80 Registered: Aug-05 | why do i not get 110 ppv, everything else fine, had this problem for quite some time never looked into it because bev always satisfied the void. 2700a |
Gold Member Username: TapemanNew York City in-HD, NY Post Number: 3717 Registered: Oct-06 | Beverly is dead the awake was last week And Charlie is dying got few days to live It's a matter of few days until we all become orphans LOL |
Gold Member Username: TapemanNew York City in-HD, NY Post Number: 3718 Registered: Oct-06 | I didn't set a date for D#N yet Not for another 6 to 15 weeks But I did set a date for B#V 2 months ago Check this Timed and dated: https://www.ecoustics.com/electronics/forum/home-video/517846.html |
Platinum Member Username: NydasPost Number: 12939 Registered: Jun-06 | This is what I said about King's accurate prediction in that thread: "King: That was not a wild guess - it is a calculated close call." |
Gold Member Username: TapemanNew York City in-HD, NY Post Number: 3719 Registered: Oct-06 | Nalin Someone was asking a question later decided to delete it It's one of the same trouble makers |
