USB to Serial cable
Username: Header108
Post Number: 58
I just bought a USB to Serial port cable from E-Bay and put a null adapter with it had the drivers with it and tried it out with a XP computer and no luck it configured the hardware but does not work when loading bins??
Any Ideas why it does not work???
Username: 1rbjac
Long Beach, CA US
Post Number: 29
I have a USB to Serial port cable and works great make sure that you have the correct port selected and that you are using the correct cable. Also, what happens when you try to upload the bin?
Username: Cartier1
Post Number: 2151
AS rj said . when u instal the driver and you hook the right cable. go to device manager and see what port number your usb cable is hooked to. when u open the loader make sure u have the same port numebr in ur configuration. and there is no way it wont work.
Username: Header108
Post Number: 59
Well I have done all that you have said and this putter doesn't work have a null adapter after the serial plug and then a gender adapter after that so I can plug it into the Receiver,In the device manager on the computer it says all is working and I have tried all the comm ports with no luck,anymore ideas????????????
Username: Mrgreg
Ont. Canada
Post Number: 45
Chas, Try each com port but back right out of the loader each time you try a different port.
Username: Kingofdakingz
Post Number: 366
i want buy one usb to rs232 too can anyone give me the link for ebay cuz i couldnt find it thanks
Username: Justforhahas
Post Number: 1074
Not all of these cables will work with every computer and receiver...
Username: Nydas
Post Number: 12922
Go to Device Manager of your computer and configure the USB to serial adaptor as Com1 or Com 2.
For serial cable - if you do not know what type it is and it does not work, insert a M/M DB9 null adaptor in between and then try.
Username: 1rbjac
Long Beach, CA US
Post Number: 30
The gender adapter is probably not compatable with the cable since the cable is not a true serial cable. You should not need an adapter if you are using the correct cable.
