Channel Guide?
Username: Leonard15
Post Number: 50
Hi guys anyone know how to get a channel guide to work for all the channels as when I put my channel to 200 (CNN) I still can't get a guide for all my locals and some other channels as I want to set my NFL favs for tommorow.
Username: Tooter
Post Number: 21
200 works good for 119w
try 119 (bio) for 110w
www.the506.com/nflmaps/index.html
Username: Post_man
Post Number: 61
Tooter once you are on 119 channel 200
how do you setup a TV guide?
When I press the EPG on my remote
the TV Guide comes up no matter what
channel that I am on. But lot of the channels are not shown.
Username: Tooter
Post Number: 25
depends on receiver-
with captiveworks, just waiting several moments on the channel fills in the guide.
with pansat you select the channel and reboot the stb and select OK for epg download.
Username: Post_man
Post Number: 62
Thank you Tooter it did work for me as you said.
Username: Leonard15
Post Number: 51
I have a Viewsat Extreme and I put my channel on 119 and left it there for a few minutes but still no guide for the 110 channels, as I only have a guide for the 119 ones. Anymore ideas?
Username: Plymouth
Post Number: 5451
Leonard
Use any channel with this Tp 12472
Username: Leonard15
Post Number: 52
So basically what you are saying is that I need to go into my Sat Settings and change the 110W TP to 12472 if it is not already set at that setting?
Username: Plymouth
Post Number: 5457
Go to User setting, EPG setting
On EPG TP , for Echostar select 12472 and Nimiq 12311 and on Receiver Guide press OK and wait, now you must have guide.
Username: Leonard15
Post Number: 53
Yes I did download the guide with those correct settings but when I go to watch tv the 110 channels still say info unavailable. I get all the 119 channel guides but no 110 for some reason.
Username: Plymouth
Post Number: 5459
Leonard
Do a autoscan on 110 and when the display ask delete channels choose yes and reload the display.
If it not work, do a total factory default on all and blindscan all satellites.
