Encoding new keys
Username: Pilong
N/a, N/a N/a
Post Number: 31
Hello there,Is anybody out there can help me? how to encode new keys on my VS ultra 2000.This is my first time to do this on how to use the remote control pls. teach me step by step first press menu then next i dont know so kindly help me please thanks
Username: Kirankumar
NO Bashing
Post Number: 3020
we need more information
what model receiver do you have?
also you do not need to input keys manually
turn your auto roll on.
also if you are pointed at b@v,you will not get any channels,as b@v has implemented a new encryption system called nagra3
Username: Wk66
Post Number: 25
The operating of your remote control is very intuitive and you don't really need anybody's help.Dont be afraid to use it.Even if you make a mistake just do not accept changes and start from scratch.Even if you go too far and mess it up good you can always do a factory reset which makes your receiver like a brand new unit again.There is no way to damage the receiver using a romote controller.You can only damage it if you throw a receiver in the air twice and catch it once.Good luck.
