Will someone please help me???
Username: Nightbreed77
I have 2 blitz audio amps (BZA-2360 1400 WATTS x 2 channel) and 2 pioneer 12" dual voice coil subs (TS-W3001D4 3000 WATTS MAX / NOM. 1000 WATTS ) What would be the best way to wire the speakers to the amps and do i need a cap. the speakers are in a sealed box. or would a ported box be better.
Diamond Member
Post Number: 22791
is that amp 1ohm stable? if so then you wire it parallel.
parallel-connect all the + together to the amp's + and all the - together to the amp's -.
you don't need a cap.
imo the ported box would be better for those subs. i had one in the past. tried sealed and ported and ported sounded much better.
im not sure if they are 1 ohm stable. im still new at this and trying to learn.any help would be greatly appreciated. thanks
Username: The_image_dynamic
San Diego, California
Post Number: 4747
It's a two-channel amp that is bridgeable @ 4 ohms.
Diamond Member
Post Number: 22792
after reading your post again i realized you have a 2 channel amp. your best bet is to connect each to one channel or bridge the 2 channels and wire your subs series-parallel.
Diamond Member
Post Number: 22793
fukkk brad beat me to it. i hate it when that happens.
thanks everyone. i appreciate all your help
Diamond Member
Post Number: 22795
your welcome vincent.
also welcome to the forum. if there's anything you need, don't hesitate to ask. there are bunch of good people here that will help you.
