Bronze Member Username: PolywogPost Number: 29 Registered: Nov-07 | now says no channel, go to menu, setup ant, when i choose which bird it reboots to no ch. |
Bronze Member Username: PolywogPost Number: 30 Registered: Nov-07 | just loaded v0143 firmware update, still same problem |
Silver Member Username: Mohamad_obamaTerhan, Iran Iran Post Number: 142 Registered: Oct-08 | Factory reset, put in all our settings...........correctly, install latest bin and scan sats.......one at a time. |
Bronze Member Username: PolywogPost Number: 31 Registered: Nov-07 | how do i factory reset? |
Silver Member Username: Mohamad_obamaTerhan, Iran Iran Post Number: 143 Registered: Oct-08 | Go into menu>system information and then factory default. This will erase all your settings. If you think you have the settings right write them down before doing this. Remember to scan ONE sat at a time. |
Bronze Member Username: PolywogPost Number: 32 Registered: Nov-07 | did factory default, installed v117, still reboots when choosing bird inant setup |
Bronze Member Username: PolywogPost Number: 33 Registered: Nov-07 | installed main pgm fail fix, still same problem |
Bronze Member Username: PolywogPost Number: 35 Registered: Nov-07 | installed main pgm fix, still same problem! |
Gold Member Username: PlymouthCanada Post Number: 5253 Registered: Jan-08 | Load this new factory file: [link removed] Now with USB Load this new Satellite info: [link removed] Load latest bin file. Reply with the result. |
Bronze Member Username: PolywogPost Number: 36 Registered: Nov-07 | powered down in back, now no display at all in front when powered on? previously it displayed noCH |
Silver Member Username: JuanchoCANADA Xx Post Number: 165 Registered: Jun-08 | by by. |
Silver Member Username: JustforhahasPost Number: 926 Registered: Jul-08 | Are you saying it has NO power at all, if so open the case and look around for loose/bad anything...and fuse.. BTW, you may also have a clone, if you never used this particular receiver before... Also u can try a transfer of data from another Ultra... All this info is available..here.. All these sites ALWAYS have the latest files, bins, how to's, manuals, guides, dish pointing calulators and tips, hardware info, jtag info, newbie and getting started sections, actively moderated with a no troublemakers and no bashing allowed policy.. and are free, and only require a simple free registration...Your email info is kept private, unless U specify differently..and U will be notified via email of any replies to any questions U may ask (or U can shut that feature off, if U like)..and your IP is sacred and never released.. Many of these specialize in particular FTA receivers as noted next to their links..USE those for your particular receiver manufacturer.. If U want real info, trouble free, no costs, friendly help, no hassles, latest files and manuals, then use these...these are well established, and have a long history, and are the best known sites throughout the entire DSS community now... Ecoustics is NOT a Dss site, since is has NO files, no manuals, no guides, little info, no specific categories, and is almost impossible to find anything because every thread here has been allowed to be hijacked (because no mods are active) and the Subject does not relate to the posts within it....also Ecoustics is basically an Electronics site for home audio, television, DVDs, stereo's, and things of that nature, NOT FTA satellite information . So again I highly recommend using ANY of these sites BELOW!....U pick one and use it for fast , friendly info and files, and many of these also have a LIVE chat area what U can get an IMMEDIATE response from reliable knowlegeable sources!...U will save yourself much time, especially if you are a newbie to this hobby!...and most all also will have the latest keys posted as well, and the keymaster, keyripper, key grabber utility files to download as well....and if plastic is your thing , some also have an area for that as well as FTA..Good Luck and enjoy this hobby! FTA Bins [link removed] (all receivers) Data Viewing Sequences [link removed] ( Conaxsat and all receivers) MarketRealm [link removed] (C00LSAT and All receivers) FTA For All [link removed] (Captain and Captiveworks) Dss Rookie [link removed] (Nfusion and others) Cut and Paste these into your browser: REMOVE the * in links below: These are the larger popular sites,and therefore Ecoustics has blocked their names and active links.. |
Gold Member Username: PlymouthCanada Post Number: 5256 Registered: Jan-08 | thehoov Now load the latest file and rescan all satellites |
Bronze Member Username: PolywogPost Number: 37 Registered: Nov-07 | removed cover to inspect power supply, found leaky cap, I'll replace it 2mar0 when electrical supply opens. keep you posted. thanks for all your help! |
Silver Member Username: JustforhahasPost Number: 950 Registered: Jul-08 | Good luck to ya hoov..at least you show some iniative, thats rare nowadays.. |
Platinum Member Username: NydasPost Number: 12807 Registered: Jun-06 | Good work, Plymouth and thehoov. Problem solved. |
Silver Member Username: JustforhahasPost Number: 953 Registered: Jul-08 | Plymouth provided all wrong advice...he had a leaky cap...hardware issue... nalin you knew that unless ya don't read english, you're just being an azzhole as usual...bite me MOLE! |
Platinum Member Username: NydasPost Number: 12810 Registered: Jun-06 | justforhaha's: And YOU told him to look all over the internet. At least Plymouth was helping. Good work, Plymouth and thehoov. Problem solved |
Silver Member Username: JustforhahasPost Number: 957 Registered: Jul-08 | NO I said.. "Are you saying it has NO power at all, if so open the case and look around for loose/bad anything...and fuse.." |
Platinum Member Username: NydasPost Number: 12813 Registered: Jun-06 | Really???? |
Gold Member Username: PlymouthCanada Post Number: 5268 Registered: Jan-08 | Haha aka LK know nothing in Viewsat, the only thing he is able to say is: go on another site. thehoov The capacitor never blow on a Viewsat but it is possible, for test it, just unhook the LNB RG-6 and it must work, if not that is propably not the capacitor. Sometimes a Vs dead receiver display nothing and you must force the factory bin file. Reply with the result and you will receive help from us on Ecoustics. |
Silver Member Username: Mohamad_obamaTerhan, Iran Iran Post Number: 146 Registered: Oct-08 | Sounds to me he knows more about electronics than you do ply mouth. |
Gold Member Username: PlymouthCanada Post Number: 5275 Registered: Jan-08 | Mohamad Obama You think? Read it: https://www.ecoustics.com/electronics/forum/home-video/471885.html See how your LK is a idiot. |
Silver Member Username: JustforhahasPost Number: 972 Registered: Jul-08 | So now plymouth is calling the guy who has the problem , found a leaking capacitor, a LIAR!...cause plymouth knows better and can tell from his hole in Canada or DN HQ! Plymouth aka nalin and other nicks make this site a complete waste of time and a joke!...which is their intentions!..as DN MOLES and RATS! |
Silver Member Username: Mohamad_obamaTerhan, Iran Iran Post Number: 148 Registered: Oct-08 | I see how your a idiot ply mouth. The man finds his problem, and you, without even seeing what he as done is calling him a liar, just because you have never had a leaking cap.................that you know of. You are a piece of human debris. |
Platinum Member Username: NydasPost Number: 12819 Registered: Jun-06 | Mohamad Obama: Go back to Iran before you become a Ecoustic debris. Can you buy capacitors in Iran? do you know what capacitors are, parrot? |
Gold Member Username: PlymouthCanada Post Number: 5278 Registered: Jan-08 | thehoov does not confirmed than it work. So wait his reply. |
Bronze Member Username: PolywogPost Number: 38 Registered: Nov-07 | the large cap was leaking and not any good, i replaced it, but still have a voltage supply problem, I know just enough to see visual problems, this goes deeper, so thursday night i'm hanging out with my electronics guru to find (hopefully) the other problems. by the way the power supply is allways on and idle when the switch is on in back, I've never turned the power off for years even in the front, i just turn off the tv. my bad. let you guys know more when i know more. thanks again for all your help with this! |
Gold Member Username: PlymouthCanada Post Number: 5324 Registered: Jan-08 | thehoov Try to load factory bin with Vs Pro loader, sometimes i do it for recover friend dead receiver, when good loader not work. Don't lose your time with power supply. |
