Bronze Member Username: MatiPost Number: 26 Registered: Apr-08 | Plymouth, As I informed you before: Loading the wrong bin file resulted in 0000 on the receiver display and a green TV screen. Both the forwarded factory file and bin file 2.05 were loaded, as advised. Results: 1. The video image consists of colors scattered all over the screen 2. Pressing "Menu" on the remote control switches the receiver off 3. Pressing "EPG" produces a PIP screen 4. No list appears on pressing "FAV" Hope this additional information will assist in finding a solution. Appreciate your support. Please advise. Regards, Eugene |
Gold Member Username: RtapFL Post Number: 2322 Registered: Jan-07 | hey young albert try this it may help.courtesy of crazyfta.net CaptiveWorks CW-600S - Loaded Wrong Bin File Problem - Repair Guide What to do when you accidentally loaded the wrong bin file... CaptiveWorks receivers are very forgiving. Either the CaptiveWorks CW-600S or the CW-600S Premium can fix itself. Just do the following.. 1. STOP - Do NOT try to put the correct bin on anymore. 2. Power off the receiver from the rear power switch. 3. Turn on the power ON from the rear AND at the same time hold in the front power button for 5 seconds. The receiver will display "BOOT" and it is now in boot mode. That is what we want, and you can let go off the front power button when this is displayed. 4. Now, load the factory bin file. 5. Next, Load the CORRECT new bin file this time. 6. Activate patch. (F1 and 000) 7. Setup dish antennas and scan channels. There you go, your CaptiveWorks CW-600S receiver is now back up and running!! |
Gold Member Username: PlymouthCanada Post Number: 5306 Registered: Jan-08 | yugene RTAP is right, try it |
Bronze Member Username: MatiPost Number: 28 Registered: Apr-08 | Plymouth, Thank you very much for your advice Every thing is working good now Thank you, Best Regards, Eugene |
Gold Member Username: PlymouthCanada Post Number: 5316 Registered: Jan-08 | You are Welcome my friend |
Bronze Member Username: TooterPost Number: 16 Registered: Oct-08 | Yeah ... good job plymutt. |
Gold Member Username: PlymouthCanada Post Number: 5320 Registered: Jan-08 | Tooter Don't talk without know. Read this thread: https://www.ecoustics.com/electronics/forum/home-video/524396.html#POST1638709 |
Bronze Member Username: TooterPost Number: 17 Registered: Oct-08 | read this http://www.youtube.com/watch?v=Y5QMw76-1nY |
