After loaded bin 302 X-05BL_081013_V302_api_nocard_F_Emu, somehow all my international channels, which are in Anik F3 - W118, are scrambled.... I did the factory reset with the latest bin file and rescanned the sat but still the same.... Any ideas? Any helps?
vijay, Where to check the AnikF3? I added this manually since it did not exist in the original sat list. I am not sure I added it correctly but before the new bin file I was able to see all Jap and Chinese channels but not any more.. Did you do the factory reset?
