Sonicview 360 premier
Username: Pegg
Post Number: 62
I have downloaded the latest firmware and since then my receiver is not powering up. A blue light indicates that the receive is getting the power, but there is nothing in the led display. Any suggestions please?
Username: Nydas
Post Number: 12851
Try loading factory BIN ad then load the latest.
Username: Adidaz2008
unplug reciver from electricity completly for 1 min then plug it back in when you get menu do factory reset then load bin again or try another bin make sure its for your reciver firmwere good luck
