Nfusion HD unable to connect to the net
Username: Canadaaka
Hi I am new with Nfusion HD I am not sure why I am unable to connect to the web. Here is what I have done:
1. I can see the ip address in network
2. I can ping it from my laptop(wireless)
3. I have rebooted the router and nfusion.
Every time i try to check the sw version it say "Failed"
Any help would be much appreciated. Thanks again.
Username: Hardrockstriker
Post Number: 1029
Does it have the correct subnet mask and gateway? If these settings aren't correct then communication from your STB won't make it past your router.
Username: Saqeeb9000
Post Number: 4118
moha reboot ur modem,then wireless router then unplug ur network cable,
Username: Canadaaka
Hi Jason and Sada thanks for replying...
The subnet mask is incorrect but everything else is ok. It has the right default gateway and DNS. I tried to do the static ip but that didnt work and for some reason it is not picking the right subnet mask.
Sada: i am not sure how will unpluging my router will help??
Please let me know if there is anything else I can do to fix this Thanks again.
Post Number: 4129
moha are u trying webloader?
or ur channels are not working?
which one u need help with
can u check that emualuator is off and autorolls are on? (check option in setting )
don't change ur ip to static?
leave it to dynamic?
what message u get when u change the channels?
let me know how it works out for ya..
Post Number: 1030
So put in the correct subnet mask. It probably should be "255.255.255.0". This will be under the DHCP server area on your router setup.
Post Number: 1031
Give me you IP addy (your "private" addy, NOT your public one on your router) and I'll tell you your settings. Make sure NOT to give me the public one, or else "they" will be able to find you. Private addies start with 10. or 192.
Username: Canadaaka
I am not sure what happened but I got a message that the receiver needs to update something and I said yes... and it did it successfuly... does this mean the network is working?? is there a way to hide my ip??thanks for all your help
Post Number: 4144
moha thats normal. that mean u are updating new bin automatically,
nothing to worry about ur internet connection is fine, u should be able to watch channels..
Username: Cartier1
Post Number: 2144
SADA DOES GLOBCAST WORKS WITH NFUSION ? I DONT HAVE A DISH BUT I WAS ASKED IF IT IS WORKING FOR GC.
Username: Canadaaka
Guys thanks alot for all your help...
Post Number: 1032
Moha, you can hide your IP using the proxy setting. Be warned, though, that this setting can slow down channel switching even more (unless you can find a non-overloaded proxy server). It's very difficult for DN or B3v to find your IP without the proxy, so I wouldn't bother; the proxy setting is there just for the paranoids.
Post Number: 1033
Moha, also be aware that the nvision update server might NOT contain the latest bin. Your best bet is to manually upload 081014_nova_v148_3.bin
Username: Extremex
Post Number: 235
Jason.
He has an HD Box. So neither of your post apply.
Post Number: 1035
Right. I should have read more carefully.
