Gold Member Username: Surferdude9371Get loud or go home.... Post Number: 1390 Registered: Mar-07 | ive checked google and cant find them to change 5x7 to 6.5 i fig cause size diff is so big but has anyone come across these? |
Gold Member Username: Big_edge_headMilwaukee, Wisconsin Post Number: 2921 Registered: Mar-07 | You could make your own if you have the equipment. |
Gold Member Username: Snowball123West Allis, WI Post Number: 1547 Registered: Oct-07 | there's a bunch on sonicelectronix.com, but i dont know about that size. http://www.sonicelectronix.com/cat_i171_adapter-brackets.html |
Gold Member Username: Big_edge_headMilwaukee, Wisconsin Post Number: 2922 Registered: Mar-07 | This should work fine. I read in some thread somewhere that 5x7 and 6x8 have the same mounting holes. If I can find it I'll link it up. http://www.sonicelectronix.com/item_4966_Scosche+SA68.html... |
