New Urdu channel SAB Tv availale on 118.7 DISH
Username: Saqeeb9000
Post Number: 4135
http://www.sabtv.com/
channel 575}
sat 118.8
freq 12063
horizontal
20000
enjoy
Username: Nydas
Post Number: 12816
Thanks, sada.
Username: Plymouth
Post Number: 5274
Thanks Sada
Post Number: 4136
u are welcome,
i just scanned it ,
for some rec it might me named as FPchn
but its sab tv.
its really good thing dn is adding more southasian channels..
Username: Nydas
Post Number: 12817
Also on TP 12063 (H) on 118.7, a new
Bangladesh channel 750 - ETV
It comes in as TV 750 on some receivers.
Username: Plymouth
Post Number: 5276
Thanks Nalin
Username: Mrskullz1
Brooklyn, New York
Post Number: 897
is it on 61.5 as well?
Post Number: 4139
mr skullz ,
nfusion definately has better time than other rec, normally when there is ecm, it doesn' t go down as other does,
so it has best up time compare to sonicview,viewsat,koolsat/neosat etc.
some flaws with the rec
u need to be connected to internet all the times.
channel change takes longer time
+ pvr doesn't work properly
their nevenio model has faster channel change but no pvr with usb
nf hd has all the feautures above that are missing,
the other box is k1 plus,
its also has better up time and during the ecm , it freeze little bit..
Username: Mrskullz1
Brooklyn, New York
Post Number: 899
thnx for the info sada...i don't think im gonna buy a new receiver just yet tho...
sada...do you know if this channel will be available on 61.5?
Post Number: 4140
i don't think so mr skullz they are moving all the international channels to 118.7 prediocally,
i think its better to get 118.7
so far i don't think this channel is available on 118.7
i think all new int channels they will add only to 118.7
Username: Mrskullz1
Brooklyn, New York
Post Number: 900
ok thx sada
Username: Nydas
Post Number: 12872
SAB TV is NOT available on 61.5W.
