Pics of the new box
Username: Frkkevin
Team DLSSuperNatural...
Post Number: 5767
..this is the smallest box i've ever built haha..
anyway.. mostly done.. needs a beauty panel and the subs :-)
Username: Wickedbass
Nashville, Tn
Post Number: 31
Nice!!!!
A pic is worth 1000 posts!!
Post Number: 18695
Good work dude! I see it's still warm where you are. Cold and windy as balls here.
What's a beauty panel?? At first I thought it was a group of ppl voting.
Username: Frkkevin
Post Number: 5770
lmao .. beauty panel is just a panel that will go over that and box off the trunk hiding everything behind
last i checked my car said 84degrees.. not sure what the high was
Username: Cozce
St. Louis ILLsideU.S.A.
Post Number: 344
I like the pink VWBeetle :-)
How big is it? :-)
Username: Frkkevin
Post Number: 5771
how big is the pink beetle?! lol
box is tiny.. ive had to alter it slightly and last i checked it was sitting right around .75 cubes per chamber.. ima have to use some polyfill on this one
Username: Loc_out
Team RE XXX
Post Number: 2615
Looking good kevin, any luck finding the second RE 12?
Username: Frkkevin
Post Number: 5772
theres tons floating around.. just have not spent the money on one..
was trying to trade my 15" first
Username: Jtown
Texas
Post Number: 3284
well sir that is fuckingphenomenal! great work
Username: Big_edge_head
Milwaukee, Wisconsin
Post Number: 2899
Damn that's looking good. Can't wait to see the end result.:-)
Username: Somedonniedude
Illinois United States
Post Number: 2048
Looks sweet!
Username: Deadrabit
Marionville, MO
Post Number: 981
looks like ur doing a very good job
Username: Frkkevin
Post Number: 5776
Either at the end of the week or beginning of next I'll get started on the fiberglass pieces for the trunk
Still gotta wrap the amprack and other pieces as well
Username: Snowball123
West Allis, WI
Post Number: 1515
Looks tight. You end up finding that 2nd XXX?
Username: Frkkevin
Post Number: 5778
yes but im waiting to sell mine before i buy
Username: Frkkevin
Post Number: 5779
maybe i'll have some teaser pics of the other panels tomorrow for you guys :P
Username: Mendonmafia
Post Number: 1496
seems like all the bass is gonna be trapped in your trunk like that. or do you have a pass through on the rear shelf?
Username: Frkkevin
Post Number: 5784
im ported the rear deck.. took off the rear panel of the seat as well.. plus the center portion of the armrest folds out to an opening :-)
Post Number: 1498
nice! i might do that to my car some day.
looks awesome either way! are you gonna put an amp(s) in the spare tire area?
Username: Frkkevin
Post Number: 5787
3 amps staggered in the wheel well.. the 2nd a6 will most likely get mounted behind the box
