Platinum Member Username: Nyyfan13Yanks Fan USA Post Number: 10543 Registered: Jul-06 | Sup fellas. As the title states, I am looking for an amp that does 1200-1500rms at 3 ohms for my RL-S. Right now I have one amp in mind and that would be the JBL BPX1100.1, as recommended by Brad. The cheapest I found that amp was $500 from sonicelectronix but they no longer sell it and I can only find the amp for around $600ish. So with that budget of $600 of under, what amp would you guys recommend for 1200-1500rms at 3 ohms? I just wanna see what other options I may have overlooked. I know its quite a random power range to look for. Ideas? |
Gold Member Username: SouthernrebelMonroe, Louisiana 3 DD3515s, 2... Post Number: 6883 Registered: Mar-04 | massive 3000d ? should be more than enough. |
Gold Member Username: SouthernrebelMonroe, Louisiana 3 DD3515s, 2... Post Number: 6884 Registered: Mar-04 | Alpine MRP-M2000 Haven't really seen any reviews, but its rated 1500wrms @ 4ohm and 2k at 2ohm. |
Gold Member Username: BonhamdPost Number: 1361 Registered: Nov-07 | maybe a keeker zx1500.1? |
Gold Member Username: Van_manBoston South, MA Post Number: 4404 Registered: Mar-06 | PP D500/1 maybe Arc Audio ARC 2500-XXK 1050 RMS @ 4 Ohms Crossfire VR2000D 1000 RMS @ 4 Ohms |
Platinum Member Username: Nyyfan13Yanks Fan USA Post Number: 10546 Registered: Jul-06 | Not a bad thought but I have heard some bad things about all the Massive Audio amps. Inefficient, overrated, almost same quality as Hifonics. What are your feelings on Massive Audio Canaan? For the record, the budget can go up if need be....someone got a raise today |
Platinum Member Username: Nyyfan13Yanks Fan USA Post Number: 10547 Registered: Jul-06 | Damn 3 posts at the same time lol. Give me some time to go look at all those. Thanks fellas. |
Gold Member Username: SouthernrebelMonroe, Louisiana 3 DD3515s, 2... Post Number: 6885 Registered: Mar-04 | Memphis 16-MCD1500 Or even Power Acoustik 5500D, hell their boards are the same as SoundStream nowdays. |
Platinum Member Username: Rovin1 15 = 149.5 DBsTrinidad & T... Post Number: 14288 Registered: Jul-05 | http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=19615 http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=19890 ....... |
Gold Member Username: BonhamdPost Number: 1362 Registered: Nov-07 | ab vfl 200.1 |
Gold Member Username: SouthernrebelMonroe, Louisiana 3 DD3515s, 2... Post Number: 6886 Registered: Mar-04 | Any good 2ch amp should be able you handle 3ohm nominal. Just keep your voltage up. |
Gold Member Username: SouthernrebelMonroe, Louisiana 3 DD3515s, 2... Post Number: 6887 Registered: Mar-04 | clarion dpx11500 |
Platinum Member Username: Nyyfan13Yanks Fan USA Post Number: 10548 Registered: Jul-06 | Bonham, any idea on pricing for one of those? I can never find a price or even find anything on them. Heres a noobish question, the Arc Audio amp Marc suggested says "1 x 1050W @ 4 ohms bridged". After box rise and everything, I should be close to a 4ohm load correct? So this amp would work just fine? BTW, thanks for all the suggestions guys. It is awesome. |
Gold Member Username: SouthernrebelMonroe, Louisiana 3 DD3515s, 2... Post Number: 6889 Registered: Mar-04 | Hell, at some freq in a ported box that amp may see 9ohm+++ |
Platinum Member Username: Nyyfan13Yanks Fan USA Post Number: 10549 Registered: Jul-06 | Fair enough Canaan. I tend to over analyze everything when it comes to buying something lol. |
Gold Member Username: SouthernrebelMonroe, Louisiana 3 DD3515s, 2... Post Number: 6891 Registered: Mar-04 | Just don't get a Boss...lol Had a guy come in the shop awhile back what had another local place install his Boss amp. The amp caught his truck on fire about 3 weeks later. It was a Chaos series amp |
Platinum Member Username: Nyyfan13Yanks Fan USA Post Number: 10550 Registered: Jul-06 | Uh oh....I hope I can return the one I just bought....It said 4000watt MAX so I figured cutting back on the gain would help...... |
Silver Member Username: Basebalz13Moneta, Va Usa Post Number: 750 Registered: Aug-07 | JL 1000/1??? |
Platinum Member Username: Nyyfan13Yanks Fan USA Post Number: 10551 Registered: Jul-06 | Thought about it. I talked to Chad and he recommended giving them more power than that. |
Gold Member Username: BonhamdPost Number: 1364 Registered: Nov-07 | not sure on the ab 200.1 price - you can email ab i think they go around 5 hundo used you could also look into the Phoenix Gold Xenon X1200.1 |
Gold Member Username: Drant19DUB-C, TX Post Number: 1290 Registered: Aug-07 | i like rovin's choice on the jbl (2nd link) |
Gold Member Username: Nd4spd18Philadelphia, PA Post Number: 8756 Registered: Jul-06 | 200.1s go for $600-700 in perfect condition..... I got mine for $500 but that was a rare deal |
Gold Member Username: The_image_dynamicSan Diego, California Post Number: 4664 Registered: Dec-06 | $560 shipped in Jersey: http://cgi.ebay.com/NEW-JBL-BPX1100-1-Mono-Channel-Car-Audio-Amplifier_W0QQitemZ 180277508831QQcmdZViewItem?_trksid=p3286.m20.l1116 I have used this amp in our demo setups of three RL-S 15's, each in 1 1/4" MDF 5 cube sealed cabs. The extension and damping factor of the Crown front end has to be heard to be believed with the RL-S. The BPX benches at just under 1300 from 1-4 ohms which is right around optimal IMO. The Crown Servo circuitry and the build quality of this amp set it apart from most. Most of the amps mentioned above would also be good. You have to remember that Chad is partly deaf. When I call him all he says is "herro anyvon dare, mudder dat yu?" over and over. Then he starts singing Chickety China. It's getting pretty annoying. |
Gold Member Username: RideredderCornell, IL USA Post Number: 1479 Registered: Sep-05 | Referring to that JBL amp,^ # Power Series Class D Monoblock Car Amplifier # RMS Power Rating: # 4 ohms: 1141 watts x 1 chan. # 1 ohm: 1022 watts x 1 chan. # Max power output: 1312 watts x 1 chan. Is that a misprint? It does more at 4ohms than one? |
Gold Member Username: JoebruceTC Sounds/DLS Post Number: 2444 Registered: May-04 | Yanks,Im in the same boat as you man. Ive got a TC Sounds LMS4000 single 3ohm. I need 1k+ too. I am pretty set on getting this amp http://www.sonicelectronix.com/item_12249_JBL+GTO14001.html I also am thinking about the JL 1000/1 or http://www.clarion.com/us/en/products/2008/audio/amplifiers/DPX11551/us-en-produ ct-pf_1172385079424.html http://www.clarion.com/us/en/products/2007/audio/amplifiers/DPX11500/us-en-produ ct-pf_1165294762631.html http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=128 http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=3351 |
Gold Member Username: Snowball123West Allis, WI Post Number: 1510 Registered: Oct-07 | out of all of those, I would say the VFL 200.1, Sexy as* amp. |
Silver Member Username: DenimSoundSolutionsAudio.com, MD USA Post Number: 809 Registered: Nov-06 | If you can find one, check out the PG Xenon X1200.1. |
Gold Member Username: Nd4spd18Philadelphia, PA Post Number: 8768 Registered: Jul-06 | " out of all of those, I would say the VFL 200.1, Sexy as* amp. " And built solid as all hell |
Silver Member Username: KingtutusLincoln, Nebraska U.s.a Post Number: 472 Registered: Dec-07 | RD 3250.1D |
Gold Member Username: SomedonniedudeIllinois United States Post Number: 2044 Registered: May-07 | Hmm...what about a AQ3500? It would be $100 over your budget, but then you should be able to add a second one down the road, if you ever feel the need that is. |
Platinum Member Username: Nyyfan13Yanks Fan USA Post Number: 10554 Registered: Jul-06 | Lmao Brad. Thanks for that find bud. eBay didn't show anything for me. I'm going to send an email to AB and find out more about the 200.1. Thanks for the suggestions fellas. I'm looking into all of them. |
Gold Member Username: FrkkevinTeam DLSSuperNatural... Post Number: 5760 Registered: Nov-05 | Coil config on the rls? |
Gold Member Username: BasssquaredKansas Post Number: 2356 Registered: Nov-06 | single 3 ohm dayum Kev your a noob |
Gold Member Username: FrkkevinTeam DLSSuperNatural... Post Number: 5761 Registered: Nov-05 | i thought that was it, just didn't know for sure.. might look into a 2 channel that puts out 1000 @ 4 ohm bridged .. after impedance rise you'd be up there how about a pg xenon 1200.1 btw |
Platinum Member Username: Nyyfan13Yanks Fan USA Post Number: 10556 Registered: Jul-06 | Thats another option I've thought about Kevin. Its basically come down to the JBL, the PG, the AB, or the Arc Audio Marc posted. I thought about the Keeker but I just don't want to get that lol. A two channel isn't a bad thought either though. |
Gold Member Username: Nd4spd18Philadelphia, PA Post Number: 8771 Registered: Jul-06 | " Its basically come down to the JBL, the PG, the AB, or the Arc Audio Marc posted. " For your setup I'd have to go with the JBL..... it just seems like a waste to buy a 200.1 only to use at 3 ohms. " A two channel isn't a bad thought either though. " Actually it is..... a lot lower efficiency. If the electrical is stock don't even consider it. |
Gold Member Username: FrkkevinTeam DLSSuperNatural... Post Number: 5765 Registered: Nov-05 | but a class AB will be a lot cleaner of an signal, so for that sub.. I'd recommend it |
Gold Member Username: Nd4spd18Philadelphia, PA Post Number: 8772 Registered: Jul-06 | The transistors in a class D amplifier are switching at frequencies much higher that a sub would ever play...... you're not going to hear any difference. Now if you tried to use a class D to drive full range speakers, then you'd hear the interference. |
Gold Member Username: JakeyplaysbassSt. Louis, MO / ASU Post Number: 3398 Registered: Jul-05 | This is perfect yanks... MMats d2000.2. They have been known to put out upwards of 2kw @2ohm, extremely small, extremely efficient. Plus its on sale! woo. http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=382 |
Gold Member Username: Snarl2004Digital Design 9515, Massive Audi... Post Number: 2459 Registered: Dec-06 | i say get a zx1500.1 could see if this guys still got his for sale: http://www.caraudio.com/forum/showthread.php?t=355794&highlight=zx1500.1 |
Platinum Member Username: Nyyfan13Yanks Fan USA Post Number: 10558 Registered: Jul-06 | Good looks Jake. Hmmm....tough decision here. |
