Platinum Member Username: Rovin1 15 = 149.5 DBsTrinidad & T... Post Number: 14270 Registered: Jul-05 | anybody still uses these ? i know long ago b4 mp3s were popular some cars used to come with these usually holding 5 or 6 cds but nowadays these new units can even play mp3s too y im asking is i do enjoy d quality of originals & id like to have access to some mp3s too instead of using usb decks or opening\closing a deck face & changing a cd often http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=12066 http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=12847 anybody here use cd changers ? : how is d built quality & music quality , good idea or not ? .... |
Gold Member Username: Nd4spd18Philadelphia, PA Post Number: 8677 Registered: Jul-06 | They are obsolete now..... been a long time since i've seen one in use..... With flash memory getting as cheap as it is USB HUs are gonna be the next big thing. Just convert all your CDs to a lossless format and put them on your portable player or flash drive. |
Platinum Member Username: Rovin1 15 = 149.5 DBsTrinidad & T... Post Number: 14276 Registered: Jul-05 | yes but some mp3s really sux in quality so thats y im wanting both options ... |
Gold Member Username: Tatonka-[Team Audible Insanity]- Post Number: 2387 Registered: Mar-07 | "yes but some mp3s really sux in quality so thats y im wanting both options ..." Just get some high quality Mp3s? |
Gold Member Username: Nd4spd18Philadelphia, PA Post Number: 8683 Registered: Jul-06 | Thats why I said a lossless format.... we just need more HUs to support those formats. " Just get some high quality Mp3s? " No such things when compared to an uncompressed original |
Gold Member Username: The_image_dynamicSan Diego, California Post Number: 4641 Registered: Dec-06 | 320kbps (and even 256) MP3's are indistinguishable from a store bought cd in a car audio application. I have trying to tell people this since I joined here. You would need a reference pair of headphones and/or a very high quality home audio system to decipher the difference. And even then it is not that easy. http://www.lincomatic.com/mp3/mp3quality.html http://www.geocities.com/altbinariessoundsmusicclassical/mp3test.html |
