Need NEw Sub Ideas
Username: Mmaudioconcepts
Post Number: 551
ok so i recently installed 2 AQ sdc2.5 12s in a 4.28 cubic foot box tuned to 36hz. Im not really satisfied. They pound but not enough for me. Im going to try a new tunning freq first. any suggestions? 38hz? then if that doesnt do the trick then i need to look for a single sub or 2 subs that can handle 1200wrms and thats at 1ohm.
Username: Mendonmafia
Post Number: 1495
u need more power then or more cone area. thats gonna be the only way to get louder.
Post Number: 552
so a more efficient sub is not an option?
Username: Loc_out
Team RE XXX
Post Number: 2617
what kind of amp are you currently running???
Post Number: 553
how much better would two Fi BL 12s on 2000+ be.
Post Number: 554
amps are not a problem. I own my own shop. I am a dealer for memphis, orion, fusion, hifonics. Plus we carry tons of other brands and get great dealer prices. I just want subs that are not too mainstream and i will power them appropriately.
Username: Southernrebel
Monroe, Louisiana 3 DD3515s, 2...
Post Number: 6900
I usually put DD2512's in ~2.35cuft w/ 16sq per cuft about 18" long. They are DAM impressive in that box.
On paper that tunes to ~42hz, but in car its great.
The lows are alot more dominant than "tune" would tell you.
In fact, as I type...my boss is demoing one in that exact box in the sound room now.
Post Number: 555
i have no clue what to try next
Username: Frkkevin
Team DLSSuperNatural...
Post Number: 5775
How about a single 04/05 RE XXX 15? :-)
Username: Deadrabit
Marionville, MO
Post Number: 990
just put a little more power do those sdc2.5s like 1k to each and try 38Hz.
that would be better but u might want to upgrade. the hdc3s are really nice.
a sinlge 15 is what i would get.
Post Number: 556
how would 1 hdc3 15 compare to two sdc2.5 12s
Username: Faroutdesign
St.ptersburg, Florida Usa
Post Number: 38
15's get lower the fi btls are sick in the 15" my buddy has one fully loaded in a 5 cube box tuned to about 40 hz with a mmats d300 hitting around 148 db people loose there mind in his back seat. i personally think the box could be bigger for better sq but most people on the street just care if it pounds
