What size?!
Username: Skatebowls
Cleveland, OH
Post Number: 10
what size subs sound the best for reggae? 10's, 12's or 15's? thank s!!!
Username: Surferdude9371
Get loud or go home....
Post Number: 1322
not a size issue its all about sq and tuning and for that i have no clue
Username: Nd4spd18
Philadelphia, PA
Post Number: 8635
Cone size has almost no bearing on the sound.
Username: Jakeyplaysbass
St. Louis, MO / ASU
Post Number: 3389
2 12s sealed is a very accurate and flat setup in the right box. Plus you still get solid SPL compared to 8s or 10s... IMO thats a very good 1st setup to try out and see what you like.
Username: Trueaudiophile
New York
Post Number: 40
Post Number: 1327
true gtfo without new people asking questions we wouldnt have a forum i suppose you were born knowing the answer jack off
New York
Post Number: 41
chill out man. if you tell people to gtfo then you wouldn't have a forum either.
Cleveland, OH
Post Number: 12
yeah your right p rick it is about tuning...i remember that from my type x...thats the thing i have no clue really...but im starting to remember traces ;) im just worried if i get 12's that when i go to turn on rock and roll or reggae the bass will sound louder than the high's and mid's, i guess thats what im worried about and i know that has nothing to do with cone size...but bear with me!!
Username: Rovin
1 15 = 149.5 DBsTrinidad & T...
Post Number: 14273
i like 12s though these days im toning it down to 2 10s ...
Username: Semperfi
i think its about the space you have as well, like 2 15"s in a trunk i don't think will sound as good as 2 12"s in the same trunk because of all the air they move and extra noise they create, 10"s and 12"s are said to have a tighter base i personally like 12"s but i have a 10" that has never been powered so i can't go off that yet
