What would be a good amp to get
Username: Creedpodfan117
Alabama USA
im looking at getting 2 exodus shiva-x and don't want to spend too much on an amp
Username: Hittin1
Lake Charles, La. United States
Post Number: 1482
What voice coil configuration and size are the subs?
What is your budget?
Username: Ctmike
Ct.
Post Number: 6631
alpine pdx 1000.1.
Username: Nd4spd18
Philadelphia, PA
Post Number: 8603
" don't want to spend too much on an amp "
" alpine pdx 1000.1 "
Username: Ctmike
Ct.
Post Number: 6633
you can buy used dipshi_t. or online we're they're under msrp. why not you try giving a suggestion.
Username: Nd4spd18
Philadelphia, PA
Post Number: 8609
under msrp or not thats an expensive amp.
Like mark said need to know VCs and budget to give suggestions.....
Username: Drant19
DUB-C, TX
Post Number: 1281
isnt the pdx same power at 1-4ohms??
Username: Heinzlmeir4
Post Number: 14
same power @ 2 ohm and @ 4 ohm yes
Alabama USA
is there a difference as far as sound goes for a lower ohm config
as far a budget goes i don't want to spend any more than 250
Username: Nd4spd18
Philadelphia, PA
Post Number: 8649
tell us what ohm coils are on the subs or we can't help you.....
no the impedance doesn't affect the sound in any audible way.
