Bronze Member Username: Andrew16639Miramar, FL United States Post Number: 19 Registered: Sep-08 | What amp should i get for my 2 Fi Q 10's. I want to put at least 1000 rms to each sub. |
Gold Member Username: BonhamdPost Number: 1278 Registered: Nov-07 | an AQ2200D would be a good choice |
Platinum Member Username: Rovin1 15 = 149.5 DBsTrinidad & T... Post Number: 14226 Registered: Jul-05 | kicker 2500 should be good too ... |
Bronze Member Username: Andrew16639Miramar, FL United States Post Number: 21 Registered: Sep-08 | any other amps? |
Platinum Member Username: InsearchofbassPost Number: 10651 Registered: Jun-04 | It looks like you have a 110 amp alternator and you need some of that for your vehicles basic electrical needs so if your going to run 2000 watts you better upgrade your alternator. |
Bronze Member Username: Andrew16639Miramar, FL United States Post Number: 22 Registered: Sep-08 | I am with a 250amp alternator |
Platinum Member Username: InsearchofbassPost Number: 10652 Registered: Jun-04 | Great. Where did you find it. |
Gold Member Username: Nd4spd18Philadelphia, PA Post Number: 8600 Registered: Jul-06 | Are you putting those in a sealed or ported box? You may have a system similar to mine..... ( 2 ) Fi Q 10" w/BP sealed American Bass 3000w amp (overkill but extra power don't hurt) 200 amp alt + 1500 amp battery |
Bronze Member Username: Andrew16639Miramar, FL United States Post Number: 23 Registered: Sep-08 | sealed box,2fi 10" w/BP, 250 amp alt, 1600 amp battery. What amp should i get to put at least 1000 watts to each sub. |
Platinum Member Username: InsearchofbassPost Number: 10654 Registered: Jun-04 | Whats your budget for an amp? |
Silver Member Username: DenimSoundSolutionsAudio.com, MD USA Post Number: 804 Registered: Nov-06 | Voice coil option on the sub woofers would help narrow down the search. |
Platinum Member Username: InsearchofbassPost Number: 10655 Registered: Jun-04 | "Voice coil option on the sub woofers would help narrow down the search." yes that too. |
Bronze Member Username: Andrew16639Miramar, FL United States Post Number: 24 Registered: Sep-08 | thier dual 1ohm subs and my buget is anything below $600. |
Gold Member Username: Nd4spd18Philadelphia, PA Post Number: 8610 Registered: Jul-06 | so you need a 1 ohm stable amp. AQ 2200d is $389 so thats well within your budget. Or a RD 1750.1 if can settle for a bit under 2kw. Other options wold be RF T20001bd IA 20.1 not sure on those prices though. |
Bronze Member Username: Andrew16639Miramar, FL United States Post Number: 25 Registered: Sep-08 | what about any amps below $800 |
Bronze Member Username: Andrew16639Miramar, FL United States Post Number: 26 Registered: Sep-08 | is a Hifonics BXi2608D or Massive Audio P 1500.1 Amplifier any good? http://www.massiveaudio.com/store/p-15001-amplifier-comes-with-a-free-ak4-wirekit-for-a-limit-c-252-p-1-pr-16163.html |
Silver Member Username: DeadrabitPost Number: 911 Registered: Jun-07 | aq2200 X2 |
Gold Member Username: BonhamdPost Number: 1299 Registered: Nov-07 | maybe mmats 3000. |
Gold Member Username: BonhamdPost Number: 1300 Registered: Nov-07 | 3000.1* |
Gold Member Username: Nd4spd18Philadelphia, PA Post Number: 8614 Registered: Jul-06 | " is a Hifonics BXi2608D or Massive Audio P 1500.1 Amplifier any good? " Nope, low quality amps that don't do rated power. With a budget of $600 why would you ever get something like that. |
Gold Member Username: Snowball123West Allis, WI Post Number: 1405 Registered: Oct-07 | I'd say get that Rockford T20001BD. |
Gold Member Username: Drant19DUB-C, TX Post Number: 1287 Registered: Aug-07 | crossfire vr2000d 2000rms@1ohm rated at 12.5v |
Gold Member Username: Snowball123West Allis, WI Post Number: 1408 Registered: Oct-07 | that would be 2000@2ohm i believe. |
Gold Member Username: BonhamdPost Number: 1303 Registered: Nov-07 | 2 ohms indeed |
Gold Member Username: Drant19DUB-C, TX Post Number: 1288 Registered: Aug-07 | oops just saw that, i meant 2 |
Silver Member Username: KingtutusLincoln, Nebraska U.s.a Post Number: 462 Registered: Dec-07 | look @ a rd 3250.1 |
