Can anyone help me, I forgot the code and I dont get the manual book when I buy it, there is only a barcode on the tape itself.. can anyone help me? the barcode is 213011830952471316. please reply to this thread.. thx b4.
if it AUVS/MONZA = Please note that code entry is only possible when the display shows "CODE". If the display shows " WAIT " then the unit may be codelocked. If this is the case, leave it switched on for up to two hours and a further attempt at code entry should be possible Code Entry as Follows: Switch Radio On - Display Shows " CODE " Enter CODE in the order it is read - eg: For Example, To Enter Code 1234 Press Preset 1 then 2 then 3 then 4 If the correct code number is now shown Press Tuning Up Button " ^ " To Enter
Ok, now my display is already CODE, but the code U gave me is wrong.. I am sorry for being impolite because asking so many question, but is there are another code? Im desperate right here..
I plan to change the becker tape for another one if this doesnt work, but if I remove the becker from my car while the code is still missing can the audio came out although I use another tape?
