Setting amp gains
Username: Bonhamd
Post Number: 1308
some people do it by ear and some people do it by dmm
i like to use dmm just to know where i am...
to calculate the target voltage - do you multiply desired wattage by impedence, then take the square root of the result?
for example
RD3250 - 3750 @ .875 ohms
3750*.875=3281.25
target voltage = about 57.28 volts
is this correct?
Username: Bonhamd
Post Number: 1312
bump
Username: Nd4spd18
Philadelphia, PA
Post Number: 8650
Yes
http://web.archive.org/web/20080104010047/http://www.subwoofertools.com/forum/se tgain.asp
makes it easier
Username: Bonhamd
Post Number: 1315
thanks MS
