Silver Member Username: Talon_es93Trinidad, Co Post Number: 813 Registered: Mar-06 | what is the badest amp you can get for under 500 that is 2 ohm stable to push 2 15" mojos |
Gold Member Username: Nd4spd18Philadelphia, PA Post Number: 8638 Registered: Jul-06 | ZX2500.1 used? |
Gold Member Username: Livin_loudPost Number: 2671 Registered: Jan-06 | ^ yup... closest thing to that i can think of is what i run actually. rockford fosgate x7. pushes around 1600w though... |
Silver Member Username: Talon_es93Trinidad, Co Post Number: 814 Registered: Mar-06 | idk if 1600 is enough... thats what i been lookin @ but idk were to get a used zx2500.. thats what i was thinging to but its like 750 brand new... does earthquake still make that 2 ohm stable 3000 watt?? i member it was a small red one |
Gold Member Username: Snowball123West Allis, WI Post Number: 1421 Registered: Oct-07 | Crossfire VR2000D? If you could find one used. |
Silver Member Username: Talon_es93Trinidad, Co Post Number: 815 Registered: Mar-06 | i'll check... thanks man |
Gold Member Username: Stateprop486PA Post Number: 1668 Registered: Jan-08 | http://www.caraudio.com/forum/showthread.php?t=357499 |
Gold Member Username: Snarl2004Digital Design 9515, Massive Audi... Post Number: 2445 Registered: Dec-06 | buy one of those kickers if you can. best bet for your money. you could try a stetsom 2k6d theres a couple floating around but some people say they arnt too reliable for daily usage. theres also a hifonics XXV colossus on ca.com, i think the guy wanted 450 or something like that. the colossus really isnt as good as the zx2500.1 but theres been some tests that show the hifonics will put out real close to 3k rms at 2ohms |
