Silver Member Username: Book77
Post Number: 154 Registered: May-06
Posted on Are these channels gone?? or switched to N3 |
Gold Member Username: Rtap
FL
Post Number: 2305 Registered: Jan-07
Posted on working here try rescanning the tp for those channels |
Post Number: 155 Registered: May-06
Posted on Hmm . Tried that no luck . SV 4000 |
Gold Member Username: Kirankumar
NO Bashing
Post Number: 3000 Registered: Oct-07
Posted on try re scanning satellite 119 |
FL
Post Number: 2306 Registered: Jan-07
Posted on jim do you have signal on those tp?? |
Post Number: 156 Registered: May-06
Posted on Im sorry should of specified BEV channels} 300 and 320. Yes i have signal |
Silver Member Username: Bernardmi
Post Number: 216 Registered: Dec-07
Posted on Same as you RTAP. Missing 300 and 320 on B3V. Autorolling forever. Same on 180 (Super Ecran 1) and 780 (Hugh Heffner). More and more channels dropping everyday. Or is it a Viewsat issue only ? |
Gold Member Username: Plymouth
Post Number: 4956 Registered: Jan-08
Posted on The Outer Limits No same thing with Cw |
Post Number: 220 Registered: Dec-07
Posted on Have I read you correctly Plymouth ??? It is NOT an issue on Cw !!!! |
Post Number: 4959 Registered: Jan-08
Posted on Sorry No, it is the same problem on Cw, i can't get those channels |
Silver Member Username: Thechiz2
The south,
Nut town
Mine
Post Number: 579 Registered: Apr-05
Posted on same on panssshhhit 3500 |
Post Number: 222 Registered: Dec-07
Posted on OK thanks for info |
