Username: Dan_white Post Number: 49 Registered: Jun-08
Saturday, October 25, 2008 - 04:11 GMT If your pushing any less than 1,000 watts or right at, would it be necessary to use the fat sh1t or would I not notice a difference in regular wire?
1000 posts!!
Post Number: 18655 Registered: Jun-06
Saturday, October 25, 2008 - 04:25 GMT What's your definition of "fat" speaker wire? 12ga? 8ga? 4ga?? 12ga is good for 1000w and much more.
Username: Andrew571 Stillwater/Edmond,
Oklahoma
Post Number: 2079 Registered: Oct-05
Saturday, October 25, 2008 - 04:28 GMT I use 4ga
Username: Dan_white Post Number: 50 Registered: Jun-08
Saturday, October 25, 2008 - 04:32 GMT fat what would 8-4ga for me. obviously 12ga is not fat when compaired with other speaker wire. Ive never understood why as big of speaker wire as power wire isn't required when the power eventually makes its way to the sub.
Username: Nd4spd18 Philadelphia,
PA
Post Number: 8678 Registered: Jul-06
Saturday, October 25, 2008 - 04:46 GMT Simple... the current going from the battery/alt to amplifier is DC. From the amp to speaker it's AC since that's how a speaker works. DC current needs a MUCH bigger wire than AC.
Username: Dan_white Post Number: 53 Registered: Jun-08
Saturday, October 25, 2008 - 09:08 GMT ah. genius insight. *claps*
Username: Ridinspinnas Windsor,
Ontario
Post Number: 475 Registered: May-06
Saturday, October 25, 2008 - 14:43 GMT i use 0 gauge speaker wire
Username: Snowball123 West Allis,
WI
Post Number: 1453 Registered: Oct-07
Saturday, October 25, 2008 - 15:26 GMT what do you think max power on 12 gauge speaker wire can handle?
Username: Somedonniedude Illinois
United States
Post Number: 2032 Registered: May-07
Saturday, October 25, 2008 - 16:36 GMT "i use 0 gauge speaker wire" Was that sarcasm or you serious lol?
Username: Rovin 1 15 = 149.5 DBsTrinidad & T...
Post Number: 14274 Registered: Jul-05
Saturday, October 25, 2008 - 16:58 GMT 12g for daily subs is fine if ur competing for spl & using powerful subs some ppl even use 8g power wire ...
Username: Hittin1 Lake Charles,
La.
United States
Post Number: 1518 Registered: May-07
Sunday, October 26, 2008 - 16:20 GMT 8ga. FTW
WI
Post Number: 1466 Registered: Oct-07
Sunday, October 26, 2008 - 16:23 GMT you think 8 gauge is necessary for running 1500-2000 watts?
Username: Loudon Post Number: 2786 Registered: Jun-04
Sunday, October 26, 2008 - 17:24 GMT no not at all 12 gauge is fine
Username: Tatonka -[Team Audible
Insanity]-
Post Number: 2392 Registered: Mar-07
Sunday, October 26, 2008 - 17:29 GMT I use 2 runs of 4awg If you are running 1500-1200, the smallest wire I would recommend is 12gauge. Although, 8gauge never hurt anyone
