Silver Member Username: KingtutusLincoln, Nebraska U.s.a Post Number: 443 Registered: Dec-07 | i am looking for about 20-25 ft of 1/0 but dont no where is a good and cheap place to get some from plz help thank |
Silver Member Username: DuckaHoughton and/or Macomb, MI United States Post Number: 545 Registered: Jan-08 | Paul Larrea... If he still has some. |
Platinum Member Username: WingmanaliveA pic is worth 1000 posts!! Post Number: 18483 Registered: Jun-06 | All out of 1/0ga. Sorry. |
Silver Member Username: KingtutusLincoln, Nebraska U.s.a Post Number: 444 Registered: Dec-07 | damn it but ok then if anyone eles have any i deas |
Gold Member Username: Big_edge_headMilwaukee, Wisconsin Post Number: 2810 Registered: Mar-07 | http://www.knukonceptz.com/productDetail.cfm?prodID=KLMX0BL |
Platinum Member Username: WingmanaliveA pic is worth 1000 posts!! Post Number: 18485 Registered: Jun-06 | Good price. |
Gold Member Username: Big_edge_headMilwaukee, Wisconsin Post Number: 2811 Registered: Mar-07 | It certainly is. |
Silver Member Username: DeadrabitPost Number: 869 Registered: Jun-07 | it is but its 90% aluminum and only 10 copper u can get the 100% copper on ebay pretty cheap too and depending on what ur powering it will make a difference. i am going to need more wire too! maybe if we all got togather we could order a 500 foot role of good stuff. it owuld b cheaper. abotu 2 bucks a foot |
Gold Member Username: Killerzracing71Post Number: 2301 Registered: Aug-05 | weldingsupply.com check it out mayne |
Silver Member Username: BrewskyPrince george, British colu... Canada Post Number: 145 Registered: Aug-08 | get a wheel or w/e of 1/0 on ebay for prob 30$? |
Gold Member Username: Snowball123West Allis, WI Post Number: 1327 Registered: Oct-07 | bruce stfu. |
Silver Member Username: BrewskyPrince george, British colu... Canada Post Number: 148 Registered: Aug-08 | ..........way to post .. your the best ,,l,, :D |
Silver Member Username: BrewskyPrince george, British colu... Canada Post Number: 149 Registered: Aug-08 | in town its pricy as shiiit a wire kit is about 300$ and per ft i think its 3-4$ its sooooooo stupiddd |
Gold Member Username: Philly306If it werent for box r... Post Number: 1332 Registered: Apr-07 | "it is but its 90% aluminum and only 10 copper" Why would the material matter as long as it can carry the needed current to your amplifier? Plus KnuKonceptz customer service ftw. Bill runs a top notch program there. |
Silver Member Username: BrewskyPrince george, British colu... Canada Post Number: 150 Registered: Aug-08 | u dont want the 100% copper stuff i bought 2 ft i think it was for my ground and i had to buy anouther i couldnt move the wire around worth shiiiiit, to stiff and there arnt nearly as many strans there alot thicker |
Gold Member Username: Philly306If it werent for box r... Post Number: 1333 Registered: Apr-07 | Actually that is also incorrect bruce. 100% copper would have the least resistance with the highest current carrying capabilities that is cheap enough to sell to the general public. Companies mix aluminum in with this to lower cost while still keeping a relatively high current carrying ability. The fact that it is stiff means it has a low strand count. Higher strand count ussually yeilds higher flexibility. With the knu KLM wire it isn't the most flexible wire but it gets the job done at a good price. If you have the coin go for the Kolossus wire. There is a huge difference in flexibility. |
Silver Member Username: BrewskyPrince george, British colu... Canada Post Number: 154 Registered: Aug-08 | all copper wire i have bought hasnt bein anything special all im saying they prob do have the good stuff it prob costs an arm or a leg tho |
Gold Member Username: Philly306If it werent for box r... Post Number: 1336 Registered: Apr-07 | For good 1/0? 1.75 a foot is about as cheap as it gets. You go get you $30 roll off ebay bruce. Then we can compare you "ebay brand 1/0" to my KLM and kolossus. Then you will be able to realize you 1/0 is actually 4awg. I'll take a vid so everyone will get to see what a dumbass looks like when they get proven wrong.;) |
Gold Member Username: Philly306If it werent for box r... Post Number: 1337 Registered: Apr-07 | Why do i even bother?.... |
Gold Member Username: Snowball123West Allis, WI Post Number: 1328 Registered: Oct-07 | true that. |
Platinum Member Username: WingmanaliveA pic is worth 1000 posts!! Post Number: 18509 Registered: Jun-06 | $1.75/ft is a great deal for true 1/0ga. Trust me I know. |
Gold Member Username: The_image_dynamicSan Diego, California Post Number: 4580 Registered: Dec-06 | |
Silver Member Username: Kingandsons07TEAM REVOLUTION Lincoln,NE Post Number: 209 Registered: Aug-08 | lol i just ordered 100' of it so i hope it works |
Platinum Member Username: WingmanaliveA pic is worth 1000 posts!! Post Number: 18510 Registered: Jun-06 | 100' of what from where? |
Gold Member Username: Snowball123West Allis, WI Post Number: 1330 Registered: Oct-07 | think he's talking about the KLM. |
Silver Member Username: Kingandsons07TEAM REVOLUTION Lincoln,NE Post Number: 210 Registered: Aug-08 | yea i am so i can do 6 runs cuz if i did the good stuff the flex or what ever it was like 350 i think |
Silver Member Username: Kingandsons07TEAM REVOLUTION Lincoln,NE Post Number: 211 Registered: Aug-08 | unless someone can get me a hook up of some |
Silver Member Username: WaresgaragestereoFort Valley, GA Post Number: 436 Registered: Mar-08 | KLMX Kable from Knukonceptz 1.75/foot great wire |
Silver Member Username: BrewskyPrince george, British colu... Canada Post Number: 155 Registered: Aug-08 | i didnt say is was 30 i said it would prob be 30... i havent orderd it and all the prices of sh*t are different in canada we get charged to shiiit with everything... how does 1/o and 2/0 rf wire compare? |
Gold Member Username: BernymacPhnom PenhCambodia Post Number: 4358 Registered: Sep-04 | "how does 1/o and 2/0 rf wire compare?" If you can't research something so simple, you should go play in traffic. |
Platinum Member Username: WingmanaliveA pic is worth 1000 posts!! Post Number: 18512 Registered: Jun-06 | |
Gold Member Username: Hittin1Lake Charles, La. United States Post Number: 1447 Registered: May-07 | JEE ZUSS |
Gold Member Username: Snowball123West Allis, WI Post Number: 1335 Registered: Oct-07 | bruce, when are you ever going to get the hint to leave the forum. |
Silver Member Username: DeadrabitPost Number: 878 Registered: Jun-07 | http://cgi.ebay.com/KnuKonceptz-Silver-Pearl-1-0-Gauge-Power-Wire-50-Feet_W0QQit emZ380070411338QQcmdZViewItem?hash=item380070411338&_trkparms=72%3A1205%7C39%3A1 %7C66%3A2%7C65%3A12%7C240%3A1318&_trksid=p3286.c0.m14 |
Silver Member Username: DeadrabitPost Number: 879 Registered: Jun-07 | this kind ! http://cgi.ebay.com/KnuKonceptz-Ultra-Fleks-1-0-Power-Wire-0-Gauge-Blue_W0QQitem Z220290785320QQihZ012QQcategoryZ32810QQcmdZViewItemQQ_trksidZp1742.m153.l1262 thats what i have! it is very flexy! 100% copper! best wire EVER! |
Gold Member Username: Philly306If it werent for box r... Post Number: 1338 Registered: Apr-07 | Very nice wire blk i agree but it is not 100% copper. |
Gold Member Username: Snowball123West Allis, WI Post Number: 1341 Registered: Oct-07 | I need some hyperflex. |
Silver Member Username: DeadrabitPost Number: 884 Registered: Jun-07 | it says "This 1/0 contains our 5145 strands of Oxygen Free Tinned Copper" either way it is very flexy! and it really is GREAT wire! |
Silver Member Username: Adelphia83Colorado Springs, CO USA Post Number: 106 Registered: May-05 | I've used both the cheapie no-name cable off Ebay, and the Knuconceptz cable. I ordered in 4awg. The Ebay cable I received was majority insulation with what looked like actual 6 or 8awg wire inside. Just looking at the outside to someone who doesn't know better would appear to be 4awg. the Kollosus (sp?) cable was exactly the opposite. The actual wire content was well beyond the minimum for 4awg. In fact I can only get one clean install in my amp after taking the insulation off. If I have to remove the cable for any reason, I have to cut the wire again and remove more insulation because the old end (after it gets clamped by the set screw) would no longer fit into the terminal-- It's that big. From the second you pull it out of the box, you immediate know that it screams quality-- At a price that can't be beat. I only buy my cable from Knuconceptz now. |
Gold Member Username: Nd4spd18Philadelphia, PA Post Number: 8582 Registered: Jul-06 | 100% copper is without question the best conductor. Whether or not the 90% aluminum stuff makes any difference or not is a hotly debated topic. |
