CW700..Loading Files NOW and Fixing problems
Username: Justforhahas
Post Number: 1051
Read before loading new bins
Instructions from Chancysand:
Quote:
How To Load New Bin Files
Installing from file versions 1.89 or before:
* Save Channel List
* Do Factory Default
* Load Bin file Version 1.93 (Follow Release Notes)
* Enter 9 or 10 Digit Serial Number Located on bottom of receiver
* Do Factory Default again
* Load current bin
* Load Saved Channel List or Setup Sats and Rescan
* Exit out of menu and make sure Patch Enabled F1 000
Installing from 1.93 or greater:
* Save Channel List if you did not do Factory Default when you loaded 1.93 before
* Load current file and do Factory Default if you get error messages
* If you had to do Factory Default now Load your Saved Channel List
Installing from a box already screwed up:
* Turn box off from rear
* Press and hold down the power button on the front of the box while turning back ON from the rear and wait till you see the word BOOT on the front display for 4 seconds then let go of power button.
* Using a 9 PIN SERIAL CABLE (NOT an USB PORT), Load Bin file Version 1.93 and follow all of the Release Notes with that file.
* Load current bin version
Installing from Factory New Box:
* Turn Box on and go to menu and do Factory Default and reboot box (This is a must)
* Load Current Release file, on reboot you will see ERROR 020 on display this is ok now Enter 9 or 10 Digit Serial Number Located on bottom of receiver after reboot do another Factory Default and reboot box again now you will not see ERROR 020 anymore on boot up.
* Load a saved channel list (reboot box after loading list) or setup box from scratch and rescan all
* Exit out of all menus and ENABLE PATCH F1 000
* Wait for Keys to roll then watch TV (could take up to 7 minutes to roll)
If at anytime it asks for a password use master password 9876 if 0000 does not work.
New receivers (factory) can also load v1.93 (after factory default), enter serial number, then load latest file, if desired.
