Amp Capacitors
Username: Samdemler
Does anybody know any good place I can get the capacitors that are inside the amps? I am looking for two of them.. Out of a hifonics brutus 1606 d mono block, On the capacitors it says jaye, vent, -40+105ºC, v80, uF2200, Again these are the capacitors inside the amplifier.
Username: N2audio
Lawrence, Ks USA
Post Number: 1630
try digikey.com or mouser.com
