Ford Gps Antenna
Username: Peanut1967
Barrie , Ontario Canada
Does anyone know where the antenna goes for a Ford Gps system?I bought a used system off a guy that wrecked his 06 Explorer.I installed it in my 2007 Ford Sport trac,but I am not sure where the antenna goes. The one side is magnetic,so does that mean I can stick it some where inside the dash where there is metal and it will still get a signal?
Username: Casual_the_voice
Yes
Need to Register?
Forgot Password?
Enable HTML code in message
