18 inch fi Qs
Post Number: 811
has any one ever sealed one?
looking at putting them in my freinds blazer around chirstmas.
he just wants to kill the lows.
i was thinking tune it to 25Hz but sealed has came to mind.
anything better than 18 fi Qs?
how low can these be tuned too?
TEAM REVOLUTION Lincoln,NE
Post Number: 159
can tune it from 28Hz to 32Hz i had a 18" and still do for sell and had a 9 cubes @ 32Hz and i love it grate sub
Rock Vegas, NC US
Post Number: 2805
I put an 18 I my friends canyon, 9 cubes at 28hz and it killed the lows. I wouldn't suggest lower than 28...
Post Number: 813
this might be a stupid thing to ask but why not tune lower than 28?
so u have an 18 Q? or is it something different? very interested! email me at worrblade@yahoo.com
Username: Livin_loud
Post Number: 2642
i tried ported @ 30hz with my first box. it was nice. low end monster. then went sealed, lost a little low end, gained a bit on the higher notes. i'd go ported.
Username: Kingandsons07
Post Number: 178
x2^^^ 28Hz kill the lows lol
Username: Deadrabit
Post Number: 817
all i want is to kill the lows.
i have never listened to something tuned that low, i am pretty pumped to get it done. but ill have to wait till chirstmas to get started
Post Number: 2643
yeah, its great having a sub that doesn't bottom out on the lows :-) i honestly didn't use my sub sonic at all
Username: Cplaya280
Pennsylvania USA
Post Number: 993
the AudioPulse Revo Subs can be tuned really low also and kills the lows i have one tuned at 32hz and its deffinetly low and hits the higher notes decent. 1 Sub cost like $400 tho
Username: Shortysetnies
Andrew Capps, NC US
Post Number: 2815
32hz isnt low... 32-35 is average
Username: Deadrabit
Post Number: 818
so can any one tell me y i shouldn't tune it lower than 28?
Username: Shade
Moxee, Wa U.S.
Post Number: 752
because u will be lower then the Fs of the sub.
Andrew Capps, NC US
Post Number: 2816
And plus, if you hear it at 28 you wont want anything more from that sub... As long as its installed right and you have proper amps and charging... Just take my word on it
Username: Deadrabit
Post Number: 819
the Fs is 24.5 Hz
i know it will be good at 28. but i want the lowest i can go
Username: Lil_justin850
Justin smith, crestview, Fl Okalossa
Post Number: 13
28 is low low youll see
Andrew Capps, NC US
Post Number: 2817
do what everyoe does and make different boxes tuned differently. I guess we can't tell you what box would work best b/c every car is different.
Username: Insearchofbass
Post Number: 10586
Going with the sub tuned at 25 hz will probably give you better output at around 30 hz if that is your focus but the upper bass may suffer.
Username: Bonhamd
Post Number: 1236
but 28hz is pretty low - i have to believe taht a Q 18 would be raping lows in a box like that
Username: Brewsky
Prince george, British colu... Canada
Post Number: 137
if he ends up getting something better then the fi Q's give me a shout with what he wants for them :D
Username: Philly306
If it werent for box r...
Post Number: 1319
Go sealed with the Q
Username: Nd4spd18
Philadelphia, PA
Post Number: 8532
Those subs do work very well sealed. I have 2 10"s.
Andrew Capps, NC US
Post Number: 2825
not saying they don't work well sealed, but w/ what he's looking for, ported is the way to go...
Username: Philly306
Post Number: 1320
With an EBP of 38.28 for the dual 1 18" and 37.78 for the dual 2 18" on top of having a somewhat higher Qts makes it a great canidate for a sealed box.
As for low end sealed would be great too. It will allow for a much less steep roll off compared to a ported box that will drop off drastically after Fb.
The loss of a few decibels is well worth the gain in overall response not to mention the space saved and ease of design of a sealed enclosure.
Andrew Capps, NC US
Post Number: 2826
guess I should word those past two statements differently. From personal experience ported>sealed in the same truck, same amp and same sub. The best way for you to know exactly what sounds better and sounds like what you want is to try for yourself and build both...
Username: Thomas_g
NM
Post Number: 2360
Had a couple of 18" Q's sealed and they were still pushing on your ears loud. I would go ported though.....
