Silver Member Username: DeadrabitPost Number: 860 Registered: Jun-07 | 2k amps cheap (cheapest i can find) need to be able to be strapped . 2k at 1ohm need 2 of them when i went to look at those md3ds it turned out they were not md3ds |
Silver Member Username: DeadrabitPost Number: 861 Registered: Jun-07 | is there anything better than this? http://cgi.ebay.com/HIFONICS-BRUTUS-BXi2608D-2600W-Mono-Car-Amplifier-Amp_W0QQit emZ220282460735QQcmdZViewItem?hash=item220282460735&_trkparms=72%3A1205%7C39%3A1 %7C66%3A2%7C65%3A12%7C240%3A1318&_trksid=p3286.c0.m14 i don't really want to spend that much. don't say they suck because they are hifonics. i am pretty sure they can handle 18 volts and i have been told they put out the 2600rms they say they do. if u have had on or had one and it sucked then tell me. but don't say tell me they are over rated if u dont know what ur talking about |
Silver Member Username: DeadrabitPost Number: 862 Registered: Jun-07 | is there anything better than this? http://cgi.ebay.com/HIFONICS-BRUTUS-BXi2608D-2600W-Mono-Car-Amplifier-Amp_W0QQit emZ220282460735QQcmdZViewItem?hash=item220282460735&_trkparms=72%3A1205%7C39%3A1 %7C66%3A2%7C65%3A12%7C240%3A1318&_trksid=p3286.c0.m14 i don't really want to spend that much. don't say they suck because they are hifonics. i am pretty sure they can handle 18 volts and i have been told they put out the 2600rms they say they do. if u have had on or had one and it sucked then tell me. but don't say tell me they are over rated if u dont know what ur talking about |
Silver Member Username: TeamrevolutionATLANTA, GA USA Post Number: 395 Registered: May-07 | If you neeed a amplifier i have a couple refurb or used 1750 or a used 5750. 5750 can play .5 daily without issue |
Silver Member Username: DeadrabitPost Number: 863 Registered: Jun-07 | email me please! worrblade@yahoo.com |
Silver Member Username: DeadrabitPost Number: 864 Registered: Jun-07 | what kind of amps r these? |
Silver Member Username: TeamrevolutionATLANTA, GA USA Post Number: 396 Registered: May-07 | www.rdaudio.net rd1750 rd5750 |
Gold Member Username: Tatonka-[Team Audible Insanity]- Post Number: 2320 Registered: Mar-07 | RD1750.1s can play even at .35 daily with no issues. I run two of them myself. |
Silver Member Username: DeadrabitPost Number: 865 Registered: Jun-07 | call me or give me a price! 416-258-0329 VERY INTERESTED! as long as they are cheap |
Gold Member Username: Tatonka-[Team Audible Insanity]- Post Number: 2321 Registered: Mar-07 | Ben, power is never cheap. You said the Hifonics was even out of your budget. |
Silver Member Username: DeadrabitPost Number: 866 Registered: Jun-07 | its not really out of my budget.. its just like ouch! so much money! i know power is not cheap,.. but it can be cheap compared to other amps with the same amount of power ya know? |
Silver Member Username: TeamrevolutionATLANTA, GA USA Post Number: 397 Registered: May-07 | i tryed to call 2x |
Silver Member Username: DeadrabitPost Number: 867 Registered: Jun-07 | really? 1-417-258-0329 my phone is one. whats ur number? email me if anything worrblade@yahoo.com i work soon so email m fast |
Silver Member Username: DeadrabitPost Number: 868 Registered: Jun-07 | or find me on myspace! http://www.myspace.com/worrblade something! .. i am guessing this is cheaper than the hifonics? |
