Silver Member Username: FrobiPost Number: 232 Registered: Aug-06 | I have a new Captiveworks 600s Premium. I did blind scan as well as auto scan but am not getting Zee cinema, B4U and Zee TV. It only scans 92 channels. Another receiver is fine getting all channels. Any help will be great. Thanks |
Gold Member Username: PlymouthCanada Post Number: 4569 Registered: Jan-08 | neil Check your satellite setting or post it ![]() |
Silver Member Username: FrobiPost Number: 233 Registered: Aug-06 | Plymouth, Satellite Echo 3 61.5 Transponder 12443/H/20000/5/6 LNB Freq 11250 LNB type Normal Diseqc LNB 1 Legacy sw off Motor None Thanks |
Gold Member Username: PlymouthCanada Post Number: 4576 Registered: Jan-08 | neil Try it and reply and give the result: for Captiveworks do a blindscan, press yes when asked for deleted old channels, do autoscan press yes for deleted old channels when asked. If it not work try it: https://www.ecoustics.com/electronics/forum/home-video/520025.html |
Silver Member Username: TherepoFtaview.com Post Number: 199 Registered: May-07 | You can muck up your TP list doing a blind scan on Echo or Bev birds. Need to do a factory default then rescan using the RED button (autoscan). Make sure LNB type is correct or you will only get about 1/2 the channels, If LNB has a "DP" logo on it, type must be Dishpro, otherwise, set to normal. Good luck. |
Silver Member Username: FrobiPost Number: 234 Registered: Aug-06 | Thanks Plymouth. Did factory default, loaded older bin (17/12/07), rescanned, got all channels, reloaded latest bin, unabled patch and works great. |
Gold Member Username: PlymouthCanada Post Number: 4578 Registered: Jan-08 | Good neil Thanks for your reply ![]() |
