Quality keeps jumping
Username: Scabz
Knoxville, Tn Us
Post Number: 412
My friends quality keeps jumping. He has both signal and quality around 80% but the quality keeps jumping from 80 to 0 pretty fast. He is using DN on echo 7,8,& 10. What's up with his setup ?
Username: Plymouth
Post Number: 4483
Bad cable contact or switch defective
Username: Scabz
Knoxville, Tn Us
Post Number: 413
I don't have a switch. So , I will check the connectors.
Username: Gregraf
Post Number: 1304
Try changing lnb setting from standard to universal or vice versa.
Username: Doreenakadj
Ontario Canada
Post Number: 2090
hubby just rewired the sat's and switches and we noticed the same "jumping" and can't get DN only nimiq
Ontario Canada
Post Number: 2091
is dn down or did hubby do something wrong? setting are all good even tried it on all receivers .. same thing "JUMPING" on Dn sats(all echostar sats)
Username: Plymouth
Post Number: 4493
scabz
Which receiver?
Username: Scabz
Knoxville, Tn Us
Post Number: 414
viewsat ultra .
Username: Tapeman
New York City in-HD, NY
Post Number: 3618
Is yor frind Jumping like this?
Now that is true Quality jumping
Username: Fredp
MY FRIEND YOUR DISH CABLE IS CLOSSE TO AN ELECTRICA WIRE.
OR IT MITH HAVE A LITTLE CUT AND IT IS IN THE WATER,
Username: Fredp
MY VSPRO IS OK NOT EVEN FREZZEN
AN GETTIN 3 SAT,118,119,110
Ontario Canada
Post Number: 2092
I use VS xtreme and hubby just bought all new cables etc... when we use the same switch and cables on nimiq it works ... we switch back to the DN sat and nothing but "jumping" on the signal it happens on my captiveworks also. We havent tried a direct connection maybe that will work i don't know.
Username: Plymouth
Post Number: 4497
Doreen who is hubby?
Username: Plymouth
Post Number: 4498
Ok i know
Doreen try to switch the LNBs, it can be defective and be sure your LNB is on standard.
Ontario Canada
Post Number: 2093
Plymouth Hubby is my husband (cominlaw) but been together for 14 years.
I will tell him to switch the LNB... I know the setting is standard... Thanks anyway.
Username: Kirankumar
NO Bashing
Post Number: 2977
dj,
the vs is very sensitive to shorts on cable mostly at connectors,
from what you are saying,ask your hubby to remove the connectors for dn at switch and lnb.now cut them back a little bit and install neww connectors making sure none of the earthing wires are shorting
Username: Plymouth
Post Number: 4499
African
oreen
Ontario
Post Number: 2092
Posted on Monday, October 06, 2008 - 07:44 am: Edit Post
The receiver, cable and switch work on Bev.
