Box building experts!
Username: Kujo
Post Number: 148
I'm trying to design a box with google sketchup. Of course sealed designs are easy to make, but I'm trying to do a ported box with an angled back to fit against my back seat. I'm having trouble trying to figure out a slotted vent for my desgn. Do any of you enclosure experts have experience with google sketchup that can help me out??
Sub is a single 12" JL audio w6v2
3/4" mdf box external lengths:
height= 14.75in
width= 26.0in
bottom depth= 14.5in
Top depth= 9.25 in
Box internal volume ~1.95cuft.
Username: Kujo
Post Number: 149
Also forgot to add that if you want I cand send you my design so far (basically a wedge box sealed) and you can add in a port? Or maybe give you some guidelines if its better to start from scratch?
Username: Hittin1
Lake Charles, La. United States
Post Number: 1422
dBLK is the eCoustics Google scetchup expert. He can and will usually help!
