VIEW SAT hd
Post Number: 45
does support 61.5
help
Post Number: 865
only with addon board If your trying to get HD channels
Post Number: 12069
FTA HD receivers are OK "as is" for BEV, but need a 8SPK board (about $160) for DN
Post Number: 46
i have BEV and 110 119 but i don't have 61.5 thanks
Post Number: 12079
Snagovac: You can't get 119 and 61.5 from the same Dish. You need a second Dish and a switch.
Please post your configurations.
Username: Justforhahas
Post Number: 435
Viewsat is dropping their 9000 HD model from their inventory..its a POS with many bugs and problems, that they NEVER could fix....so now they are comin out with a new POS called the VS MAXHD, that will be their doom..
Username: Plymouth
Post Number: 4387
All bugs are corrected with new factory bin and latest bin file.
Check on Viewsat Dealer Forum
Post Number: 436
LMAO...that is the farthest thing from the truth..the VS 9000HD is garbage and being discontinued..so now Viewsat is going to sell ya a new piece of garbage, cause they couldn't fix the 9000 HD, and they need the sales to offset their legal woes....
Username: Nydas
Post Number: 12105
Plymouth: What she is trying to say is that the Viewsat authorised dealers have stopped advertising at her sites.
Username: Plymouth
Post Number: 4395
Sorry Nalin as you know i dont understand easily the english, but i have translated it and you are right, Viewsat get out Lk and her friends.
Now i understand why she don't like this receiver.
Post Number: 437
I think Viewsat had great receivers when they first came out with their Platinum and Extreme, when Pansat starting going downhill...but began slipping with the others with the Ultra ver 1...and their support is OK still, BUT
Viewsat PVR sucks and their 9000 HD really sucks, and have now been far surpassed by Conaxsat and Sonicview, just like when VS got better than the old Pansats..
Username: Plymouth
Post Number: 4401
Haha
I agree with you Vs PVR and 9000HD are a flop but the new MaxHD is a brand new not a copy of 9000HD
New info on MAXHD:
"""The tuner is in the hardware just the software needed to make mpeg4 work is on the usb drive that you need to always have pluged in to one of the USB ports."""
Again with this info we can think Turbo HD can be work on this receiver.
More to come
Username: Jjgee
Palatine, IL USA
Post Number: 175
Plymouth, it isn't going t happen. They don't even have a 8qpsk for it yet. This is junk.
Username: Plymouth
Post Number: 4403
The 8qpsk for present Dn HD is out, but for Turbo HD surely not.
This receiver is use by few user and work very fine.
PVR work fine too
Username: Rekman
Mntl-Quebec-...
Post Number: 434
PLYMOUTH how r u my friend???
wat happen DN down ??
any new bin ??
please help.. thank you in advance..
Username: Plymouth
Post Number: 4410
MKM
Fine thank you and you my friend?
Dn is up
Username: Rekman
Mntl-Quebec-...
Post Number: 435
plymouth where can I get Bin for viewsat ultra 2000...
At my place its not working.. saying NO VIDEO OR AUDIO..
I dont know wat this mean...
As I said before this receiver is weird to me...since its new....
days ago its was AUTOROLLING now
no video or audio...
.. please help.. thanks
Username: Plymouth
Post Number: 4411
MKM
here is the new file
Direct link
[link removed]
Unzip it and load it and all will be OK, this file is out since 3 days
Username: Jjgee
Palatine, IL USA
Post Number: 176
Nice hijack.
The new vs hd is still junk.
Username: Plymouth
Post Number: 4425
News on Viewsat MaxHD from a user
i get my add on module and it is working great , i get all hd channels
Username: Johnny67
Post Number: 64
Everyone says you need an add on module for viewsat Max HD, on viewsats sight they say the 8psk is built in, is the module for 1080P, and the receiver does 1080I, not everyone has a 1080p TV, my tv is the old 1080I, please advise.
Username: Plymouth
Post Number: 4426
johnny67
the 8psk is only to get hd air channels, a VS MAXHD Adapter Board (VSMAXHD-AD)60$, it looks like a USB memory adaptor and of course needs to be plug in the USB plug.
This module is not 1080p but 1080i and 720p.
Username: Johnny67
Post Number: 65
Then why would anyone even bother with the Viewsat Max HD, it does not get atsc signals, it only does Fta Channels, it sounds like a waste of money when the viewsat 9000 or Sonicview 8000 are a better investment because they get atsc channels as well as fta with the 8psk module.
Username: Plymouth
Post Number: 4431
johnny67
Sorry i forget some word
the inboard 8psk is only to get hd air channels, a VS MAXHD Adapter Board (VSMAXHD-AD)60$ is available, it looks like a USB memory adaptor and of course needs to be plug in the USB plug.
Username: Dimwitt
Post Number: 922
please provide a link to where you get your information from--
looking at the vsmaxhd i don't see an input for the over the air antenna and the VS MAXHD Adapter Board looks like a board that goes inside the maxhd and doesn't look anything like a usb stick.
Username: Dimwitt
Post Number: 923
nevermind -- it looks like you c/p from abadss.com
Post Number: 446
It doesn't have an ATSC tuner. Nor does it have a port for an External tuner on the Rear. The 8psk module is extra and an add on.
It is basically a VS9000HD trimmed down, however it does use different firmware and will not use the same type of add-on module as the VS9000HD.
Viewsat Max HD 8PSK Module Installation
The new Viewsat Max HD 8psk tuner module, SK200, is shown in images 01a, 02a, and 03a. First be sure the unit is unplugged from AC power. Next remove the top cover of the Viewsat Max HD by removing the screws at the rear of the unit.You will remove the current tuner module of the MAX HD pictured in image 04a. When removing the tuner module be careful not to bend the 4 pins in the corner. These are guide pins used to help guide the Add-on Module into place. You can see these circled in image 05a and also in the last image, which shows the empty slot before the new 8psk module is installed.
After you install the new 8psk module, replace the cover, plug into AC power, and go to Menu > System Information > Receiver Information.
You should see Optional Tuner Found. You can now scan your satellites to pick up Turbo 8psk channels on DN.
Username: Plymouth
Post Number: 4432
Thanks for this info from livefta
You confirm what i says on Turbo HD
King your comment on it please?
Username: Plymouth
Post Number: 4435
Tooter
Yes i take few info on abadss
Username: Pulpfiktion
Post Number: 361
Hey justforhaha's - u sound like someone i no.
Keep this gy out.... He bad....
Username: Plymouth
Post Number: 4470
King
Please comment it
Thanks
