Bronze Member Username: Link119805Post Number: 24 Registered: Sep-08 | Guys...I am trying to setup a 118.7, 119 AND 110 ON A DN1000+. Any pointers or help would be appreciated. First time at this... thank you. |
Gold Member Username: RunnerguyPluto Post Number: 1573 Registered: Sep-06 | Dish 1000 A three slot DBS dish designed to pick up 110A°, 119A° and 129A° simultaneously. This dish can be used to pick up 129A° and 148A° simultaneously. |
Silver Member Username: MuchoPost Number: 760 Registered: Dec-07 | Steve M, try here it's not 1000+ but installation is the same. http://www.youtube.com/watch?v=hAU_iBQgyCw |
Bronze Member Username: Link119805Post Number: 25 Registered: Sep-08 | thank you White Hawk... |
Platinum Member Username: NydasPost Number: 12097 Registered: Jun-06 | Black hawk: If the guy could afford $649 for a super Buddy, he would not be asking questions on this forum. A satellite installation guy will do it for $70-80. You need to connect 119 to Input 1 118.7 to Input 2 110 to input 3 129 to input 4 (if you have a 129 LNB) If you must DIY, then buy a SF95L signal-meter from Sadoun.com or similar. Use installation instructions posted by sadoun.com http://www.sadoun.com/Sat/Products/Accessories/Meters/SF95L-DSS-FTA-Satellite-Si gnal-meter.htm If you do not have Anik 3 listed, use Anik 1 slate in your antenna setup menu for 118.7W. LNB freq=10750 (lo 9750) Do a Blind scan or scan all with first TP as 11715 (V) (See Lyngsat for 118.7 TPs) For 119W use LNB freq 11250 and first TP 12224(V) or 12239 (H). For 110 use LNB freq 11250 and first TP 12224 (V) Blind scans get all the currently active TPs |
Bronze Member Username: Link119805Post Number: 26 Registered: Sep-08 | Thank u Nalin again! A couple questions since you have guided always in the right direction... I have pan 9200hd. If I do have Anik 3 listed then what do I do? I am not at home right now so I can not see it..Also, should I "add" all the tps for 118 in the sat...whatever one exists as well? I will most likely not put the 129 on dish. I have a dn500 with 61.5...Can I run the 61.5 into the Dp44 that I will use? Thank you.. |
Platinum Member Username: NydasPost Number: 12101 Registered: Jun-06 | You can run maximum 4 LNBs on DP44 (max 3 on DP34). You can therefore run 61.5 to your DP44 if the 61.5 is on a separate Dish. If you have more you can cascade or use other techniques - ask KING. If you have a Anik 3 slate on your receiver use it. A Blind scan does not bother about your TP list. In some STBs it overwrites the list, in others it adds the TPs. Another type of scan may only look at the first TP and then scan everything after it. Another type of scan looks at the TP list and scans only those. |
Bronze Member Username: Link119805Post Number: 27 Registered: Sep-08 | thanks Nalin......If I put the 129 on the the 1000+ it will give me 4 on the dp44. Now let's say I want to add the 61.5 from another dn500 dish...How can I do that? thanks... |
Bronze Member Username: Link119805Post Number: 29 Registered: Sep-08 | Sorry Nalin...I just asked the question that you told me to ask King... |
Bronze Member Username: Link119805Post Number: 31 Registered: Sep-08 | Nalin..One other question...In the setup above I have a pan 9200hd and 3 pan 3500sd...On which port should I connect the 9200 on the dp44? Does it matter? |
Gold Member Username: PlymouthCanada Post Number: 4374 Registered: Jan-08 | Steve here is all switch connect for Dp44 http://www.sadoun.com/Sat/Installation/Dish+Network+Installation+Guides.htm |
Bronze Member Username: Link119805Post Number: 32 Registered: Sep-08 | Thank u plymouth...I looked at it...I have 4 sats allready going into dp44 and I need to hook up another one (61.5)...the fifth one...Maybe I missed one of the diagrams but I did not find anything..iis it me? thanks |
Gold Member Username: PlymouthCanada Post Number: 4377 Registered: Jan-08 | Steve how many receivers? |
Bronze Member Username: SolopotPost Number: 24 Registered: Oct-06 | Can i install 118 togethr with 119 on 18" dish? |
Gold Member Username: PlymouthCanada Post Number: 4378 Registered: Jan-08 | solopot No you are not able to get 118.7W 30" and bigger is required |
Bronze Member Username: SolopotPost Number: 25 Registered: Oct-06 | Thank, Can i get it with Dish 500? |
Gold Member Username: PlymouthCanada Post Number: 4379 Registered: Jan-08 | Steve I found this but i dont know if it work on Dp LNB http://sadoun.com/Sat/Installation/Multi-LNBF/1-receiver-8-lnbfs.htm |
Bronze Member Username: Link119805Post Number: 33 Registered: Sep-08 | plymouth...i have 4 recvrs...1 is pans 9200hd, the other 3 are pans 3500sd... thank u |
Gold Member Username: PlymouthCanada Post Number: 4381 Registered: Jan-08 | solopot No only dish 1000 |
Gold Member Username: PlymouthCanada Post Number: 4382 Registered: Jan-08 | Steve Here is the way to get with 4 receivers and 8 LNBs, but use only 3 4x4multiswitch http://sadoun.com/Sat/Installation/Multi-LNBF/4-receiver-8-lnbfs.htm I dont know if it work on Dp LNBs, but you can E-Mail Sadoun and surely they will help you. |
Bronze Member Username: Link119805Post Number: 34 Registered: Sep-08 | Ok...thank you Plymouth... |
Gold Member Username: PlymouthCanada Post Number: 4386 Registered: Jan-08 | Steve M You are Welcome |
