Dish 500 plus, pansat 3500sd, 118
Denver, Colorado USA
Post Number: 37
I had a dish network guy come and install new dish 500 plus with switch DP 34. I spent good 4-5 hours reading various forums on how to setup pansat so that I can get channels from 118.7, 119 and 110.
I see echostar 7 in the list. I did a blind scan but it comes back with zero results. I am using 11250 and lnb local fre, lnb type as dish pro and standard both. Signal and Quality changes depending on the tp. I tried doing blind scan, tp scan but it does not return any results.
I don't see Anik-F3 in my SAT list.
I added new SAT with that name but don't know what to add for lower freq etc. I used some freq listed in some forums. How do I add all tps required.
Why does the EchoStar 7 does not pick up any channels at all.
When I connect the original DISH Network receiver it shows 3 sat:
1a and 1b - 119
2a and 2b - 110
3a and 3b - 118
I tried to change the DisEsq from 1 to 3 few times but with no luck.
Can you please help me resolve this problem.
I am in Arizona
Post Number: 39
I live in Phoenix,AZ.
Need to access 118 .7 but does not show up in list using pansat 3500 SD
Please help
