NALIN<PLYMOUTH<ANYBODY WITH INTERNATIONAL KNOWLEDGE
Username: Det
Post Number: 86
I need help getting zee tv. my dish i think is 33 inches. I have lnb 110,119, and 118.8. I have some missing channels such as zee tv and set. how can i get these channels? I do have zcinema and setmx. i there any way i can get them?
Username: Nydas
Post Number: 12011
m_n_m: I just tested 118.7 yesterday. ZEETV and a few others refuse to show up although they are on the list. Perhaps today's ECM and new BINs will change this.
Username: Plymouth
Quebec city, Quebec Canada
Post Number: 4255
m_n_m
You can try to delete the satellite and do a blind scan.
Username: Mucho
Post Number: 739
Plymouth
Username: Plymouth
Quebec city, Quebec
Post Number: 4255
Posted on Tuesday, September 30, 2008 - 07:02 am:
m_n_m
How in the hell can you delete the Satellite and do a Blind Scan ?
Username: Plymouth
Post Number: 4259
In Viewsat
Menu
Installation
Channel Scan
Choose the satellite you want delete.
On garbage can press "OK" save
Exit and Save
Return in Antenna Setup
do settings on the satellite you want Exit and Save
Do a blind scan, Exit and Save
On CaptiveWorks
Only blind Scan on the satellite you want delete, then when Delete all channels is ask, choose Yes "OK"
Save and Exit
Username: Det
Post Number: 87
how do i delete the satellite on a pansat 2700a and do a blind scan?
Username: Det
Post Number: 88
is there any other satellite i can scan to get these channels? My dish looks like this.
http://videocitydfw.com/osc/images/DISH500Plus.jpg
Username: Nydas
Post Number: 12014
On Pansat 2700 and converted receivers, you go into Menu/Channel edit and you will be able to delete individual, channels or whole satellite.
To delete a satellite from the Antenna scan menu, go to menu/Dish Installation Antenna setup and find the sat you want to delete. Press right arrow and it will be removed from scan menu. It is good to first go into that sats details and mark the DisEqC connection to "None", before deleting the sat from scanning list.
Username: Plymouth
Post Number: 4260
Thanks
Nalin
MNM
Use Advance scan(Blind Scan on Pansat) for get new Tp
Username: Kirankumar
NO Bashing
Post Number: 2965
deleting a satellite is not a good idea, especially for newbies,because it causes problems.
load the latest bin,make sure your antenna settings are correct (especially lnb type)
and scan for channels
Username: Nydas
Post Number: 12017
On Pansats as discussed above, Delete satellite means delete all channels on satellite, or delete it from the list of satellites activated for scanning.
The satellites still remain in the list of satellites.
Username: Nydas
Post Number: 12019
m_n_m:
You have the right dish.
There have been problems scanning ZEETV and a few others on 118.7. I have already told you so and I do NOT have any solution to offer.
3. If the internationals is all you want, then you can MOVE THE DISH AND scan 61.5 to get ZeeTV, but you will lose ZGUJ and a few others.
4. If you must have everything, you will have to have separate Dish for 61.5 using a DISH LNB, to process it through a DP44 to get all four, 61.5,110,118,7 and 119
Username: Det
Post Number: 89
I need all american and all international. SO you guys are saying that i should blind scan anik f3? if so what should be on the information such as
lnb type
lnb frq
etc.?
Username: Mucho
Post Number: 747
Nalin Nyda
Username: Nydas
Post Number: 12017
Posted on Tuesday, September 30, 2008 - 10:45 am:
In the English language when a person tells you to delete a Satellite he means for you to delete a Satellite no ifs no butts. Nalin Nyda your friend Plymouth told the man this: You can try to delete the satellite and do a blind scan
and you Sir are full ofshit
Username: Plymouth
Post Number: 4268
Username: Mucho
Post Number: 751
m_n_m
If you want to do a Blind Scan on Anik F3 @ 118.75*W here are your settings.
Do not delete this Satellite before you Scan. If you do like Plymouth told you to, needless to say there will be nothing there for you to Scan.
LNB type...........Standard
LNB Local-Freq. ...10,750
22KHz................OFF
DiSEqC.....what # you have assigned to Anik F3
Positioner Setting........Disable
Username: Det
Post Number: 90
i dont know the number assigned to my diseq C. i tried but no zee tv.
