Jl 13w7 in wired in series
Username: Bigntasty
Post Number: 14
does anyone know if its possible to wire 2 13w7 in series into a 3 ohm load.
the reason i ask is because i heard that the 13w7 are a dual 1.5 ohm v/c and it only has a single +/- terminal post because its configured inside the coil.
i need to know before i buy them.
and if ur wanting to know why i ask this ? is because i plan to buy 2 more in the future and the amp i will be using is rated 1 ohm stable.
Username: Evildoughboy08
Toledo, OH US and A
Post Number: 176
lets say you have 2 W7 13s.on a monoblock amp.
connect the + on one to the + on the amp.
then connect the - on the second one to the - on the amp.
then connect the + and - that arent being used on the subs together. this should create a circuit and keep the impedence at 1.5 ohms.
Toledo, OH US and A
Post Number: 177
and no, you can't get a 3 ohm load out of a W713, not possible. its automatically a 1.5 load when its hooked up
Username: Wickedbass
Post Number: 9
Agreed, that's how I have mine wired.
To clarify you can get a 3ohm load out of a SINGLE 13w7 just not two which is what I belive Lucas was getting at.
This may help.
http://http://mobile.jlaudio.com/support_pages.php?page_id=161
Post Number: 10
Messed up on the link, this should do it.
http://mobile.jlaudio.com/support_pages.php?page_id=145
