Got a problem with error
Username: Drant19
DUB-C, TX
Post Number: 1257
hu: pioneer 780mp
it gave me this error today while i was cruisin around. the HU has been skippin a lot lately and it finally stop playin the cd and gave me "error-12"??
any help?
Diamond Member
Post Number: 22447
have you tried pushing the reset button on the hu?
Username: Drant19
DUB-C, TX
Post Number: 1258
nope.. should i try that?
i turn it off and then turn it back on and its back to normal but it keeps coming back a few minutes later when the bass hits hard.
Diamond Member
Post Number: 22448
it won't hurt to try. it will reset your hu so you have to re do all your settings again.
also you might want to get a lens cleaner and give it a clean. maybe some dust got in there and its making it hard to read the disc. i assume the radio and other things work right?
Username: Drant19
DUB-C, TX
Post Number: 1259
yeah everything else is workin. this is the only thing giving me a problem.
where do i reset it?
Diamond Member
Post Number: 22450
look on the front of the hu. there should little button flushed in to the face. you would need to use a pen or something sharp to push it.
Diamond Member
Post Number: 22451
Username: Drant19
DUB-C, TX
Post Number: 1260
Chad Lee FTW! hah
