HU Hefner Unregistered guest | I crushed him...mess with the bull and get the horns |
tonto Unregistered guest | he used my name to give me a bad repitation in here so im glad hes gon for good to |
New member Username: More2itPost Number: 6 Registered: May-04 | You 2 rump rustlers should hook up...like you do on every thread. The rest of us know you for what you are. |
tonto Unregistered guest | you f#cken loser hefner quit using my name |
Lone Ranger Unregistered guest | I thought you left, Mr Tonto? |
QQQ Unregistered guest | will you biatches stop it ??? |
tonto Unregistered guest | you said you left cali777...liar |
tonto Unregistered guest | qqq i never posted that its not me sorry |
HHH Unregistered guest | losers |
Cali777 Unregistered guest | I'm baaaaaack |
Shrek2 Unregistered guest | I highly doubt your baaaaaack, cause i talked with the Real Cali777 on another forum he said he wasn't coming back to ecoustics.com & anybody using his nickname is a Fraud!!! so whoever you are you are a SCAMMER... |
Cali777 Unregistered guest | That was me you were talking to! |
Shrek2 Unregistered guest | allright if it was you tell me the site we both belong to??? then i will say ok Cali777 is back untill then i will say you are full of it!! |
Cali777 Unregistered guest | It was on http://www.bway.net/nambla.org/ ...you know...your homepage. |
Shrek2 Unregistered guest | Yup just what i thought you are that Bogus A-ole using Cali's nik |
Bronze Member Username: More2itPost Number: 12 Registered: May-04 | Get a life loosers |
Cali777 Unregistered guest | What is a "looser"? You spell like tonto/kong you illiterate b@stard. |
New member Username: ElgringoviegoPost Number: 2 Registered: Jun-04 | Will the real Cali777 step up to the plate and knock these pretenders to your throne back into the swamps from whence they oozed?!? |
