Dell W3000 Doesn't Turn On
Username: Ontarff
Post Number: 10
Sometimes my Dell W3000 30" HDTV does not illuminate when my computer is turned on although the green power LED is illuminated. It is in stand-by (LED is yellow) when the computer is shut down. To correct the problem I have to toggle the power button off and on to get the TV to display my desktop.
Username: Hobbledehoy2007
I have this same problem. I believe that the inverter is messed up. If you get more information, could you share it with me? I'll do the same.
Username: Dean5101
I have the same problem i have found a trick to get it to turn on now, but it still is a pita
Username: Howarddd
Dear Dean - Would you please share your trick to get it to turn on? Many thanks!
Username: Brucepbarrett
Heath, OH
Hi,
Does anyone know where one may obtain parts for the Dell W3000 and/or OEM Model?
Thanks
Bruce
Username: Ps_runner
Palm springs, Ca USA
I have the same problem. I am collecting reports of the same and sending them in to the State of California Department of Consumer Affairs. You can help out by forwarding the nature of the problem with your Dell W3000 LCD TV to my email address. I can keep you updated if you like.
Username: Abcomputers
here is the best place to buy parts for dell w3000
http://lcdpartsandrepair.com/
