can someone help me find links to explain how to hook satellite echo3, 7, 8.6 in such a way to allow sonicview 360 elite dual tuner functions to work. what switches do i need?
Note There is only 4 satellite Each LNB must be dual to support 2 tuners Single LNB will never support dual tuners
The DPP stacking way
This method requires: - All DPP LNBs - Either DP34 or DP44 switch - DPP Separator
This method depends on DPP polarity stacking It will stack 4 polarities on a 20 Volt single coax cable able to carry 2 tuners each equiped with 2 distinct polarities But must be separated before the dual tuner receiver using the dpp separator Also be careful all 3 items above are required Polarity stacking will never work without all 3
